3 Pages V < 1 2 3 >
> Oil line on a six, hose and valve installed!
johnlush
post Aug 25 2020, 08:50 PM
Post #21
What's all this then?
The early lines like yours can be rebuilt as long as the fittings aren't too bunged up. The replacement hose is 22mm ID x 30mm OD and can be sourced from BelMetric and probably other places. If your fittings are toast you can buy new lines or fittings and hose and have them crimped. Wasn't a member here selling sets of new lines? MB911?? I have a Cohline crimper and would be happy to help you if needed.
rgalla9146
post Aug 26 2020, 04:45 AM
Post #22
Don't discard your original plumbing.
As mentioned they can be rebuilt.
If you chose to rebuild avoid putting a ChannelLock on the aluminum
collars, they are dated and have value with your car. Use a strap wrench or find
someone familiar with these fittings. Some of us on this site have done this.
Crimped style replacement hoses are available.
Removing the tank with the first hose attached is either impossible or a very big
challenge. It's a toss up.
Pictured is a tool to reach into the fender for the first fitting off the tank.
mlindner
post Aug 26 2020, 08:07 AM
Post #23
Does the Rothsport valve need to be put into a cut hose or does it have threaded fittings. Mark
Krieger
post Aug 26 2020, 08:45 AM
Post #24
QUOTE(mlindner @ Aug 26 2020, 07:07 AM) *
The rubber hose is cut.
fixer34
post Aug 26 2020, 08:46 AM
Post #25
QUOTE(johnlush @ Aug 25 2020, 09:50 PM) *
Ahh, so that's how they come apart. Nope, not something I want to try on my own. The fittings seem to be in pretty good shape. This curved pipe piece is still attached to the tank and I'm going with the 'if it ain't broke...' for that part. I did clean up the rust around the fitting nut and it seems like it will be fine to reconnect the other piece.
The second picture is what the original objective was/is. (why does swamp and alligators come to mind...)
So if you are willing to tackle it, I would be glad to ship the pieces out to you and pay for time/materials/whatever. If you have a couple short pieces of hose, great, otherwise I'll see if I can find the proper size and send that also.
PeteAttached Image Attached Image
fixer34
post Aug 26 2020, 08:50 AM
Post #26
QUOTE(Krieger @ Aug 26 2020, 09:45 AM) *
See my original pictures, and the one I just posted with the line off. On a factory car with heat exchangers, there is really only one place it will fit and that is right next to the oil cooler.
fixer34
post Aug 26 2020, 08:58 AM
Post #27
QUOTE(fixer34 @ Aug 26 2020, 09:50 AM) *
Here's one with the heat exchanger on. The clamp attaches to the heat exchanger there is just enough room for the valve between it and the fitting. The rest of the hose has too tight of a bend to insert the valve.Attached Image
johnlush
post Aug 26 2020, 10:06 AM
Post #28
I'd be glad to help but honestly if you've gotten this far you can easily do it yourself and get back on the road. Removing the fitting from the collar isn't that difficult. Use a rubber strap wrench to hold the collar and just back out the fitting. Clean up the fittings, measure and cut new hose and put it all back together. I would suggest this hose as it has an abrasion resistant outer layer.
Belmetric Hose
If you really don't want to mess with it let me know and we can work something out. (IMG:style_emoticons/default/wavey.gif)
John
fixer34
post Aug 26 2020, 10:39 AM
Post #29
QUOTE(johnlush @ Aug 26 2020, 11:06 AM) *
Belmetric Hose
John
That's the hose I was just looking at, I'll get it ordered. Once I have it, I'll give the collars a try and let you know if I could use your services.
The car hasn't been out in at least 6 months, so another week or 2 isn't a big deal. That's why I'm going thru all this so I can drive it more and not deal with big oil leaks.
Thanks again.
Mark Henry
post Aug 26 2020, 12:48 PM
Post #30
that's what I do!
QUOTE(fixer34 @ Aug 26 2020, 10:46 AM) *
Too me the cooler end is cut a little too close, you want to make sure the two barbs don't touch, I'd want 1/2"-3/4" space between the valve and cohline barb tips.
fixer34
post Aug 26 2020, 03:05 PM
Post #31
QUOTE(Mark Henry @ Aug 26 2020, 01:48 PM) *
Got it. Ordered a meter of hose today so I have some to 'play with'. I'll cut a short piece and mount the valve, then measure, and cut back if needed, the cooler side.
porschetub
post Aug 26 2020, 03:20 PM
Post #32
You have to use a special hose with the reusable fitting,can't remember what its called,hydraulic hose shops will have it.
The alloy outer is course left hand thread ,I used to cut a small chamfer with a sharp blade to help the inner to screw in ,just make sure you put a little oil on both parts and you will be good.
Cairo94507
post Aug 26 2020, 05:40 PM
Post #33
Michael
@rgalla9146 Thanks for the tip about the Stoddard wrenches. I just ordered set. Of course I had to toss in a new T-shirt too. (IMG:style_emoticons/default/beerchug.gif)
porschetub
post Aug 26 2020, 09:10 PM
Post #34
QUOTE(Cairo94507 @ Aug 27 2020, 11:40 AM) *
Michael you can get one of these made mine works good with my car,you can get the very last of oil left in the tank and it seems to help vent when draining from the case.Attached Image.
Keep enjoying that stunning car (IMG:style_emoticons/default/smilie_pokal.gif) .
post Aug 27 2020, 05:59 AM
Post #35
914-6 GT in waiting
QUOTE(porschetub @ Aug 26 2020, 11:10 PM) *
Make sure to safety wire. You could loose all your oil in minutes if that bolt gets loose.
rudedude
post Aug 27 2020, 07:18 PM
Post #36
I like the wrench for the tank connection. Sure beats replacing the tank 3 times getting the angle correct as i recently did.
gms
post Aug 27 2020, 08:10 PM
Post #37
@fixer34 looks like got it apart?
fixer34
post Aug 28 2020, 04:21 PM
Post #38
QUOTE(gms @ Aug 27 2020, 09:10 PM) *
Making progress. Yes, your wrenches helped immensely. Put 18" of pipe on each one and that provided enough force to break it loose without damage. Cleaned up the surface rust around the nut, threads all look good and even did a test fit back together. Cut the hose to install the valve, but 50yr old rubber doesn't stretch anymore. So ordered a length of reinforced hose, it came today. Valve goes in much easier, but now I need to remove the cohline fittings and out them on the new hose.
porschetub
post Aug 28 2020, 05:41 PM
Post #39
QUOTE(mepstein @ Aug 27 2020, 11:59 PM) *
No need the bung thread is tapered,and has a wee lick of blue Hylamar ...going nowhere,cheers.
914forme
post Aug 28 2020, 07:36 PM
Post #40
Where do you get the 30mm to 30mm with drain plug?
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 02:57 PM
