| JmuRiz |
Sep 1 2020, 08:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Good coolers...I might go the W123/126 route too (if I end up with a front cooler). I had one of the W123 coolers on my M110 euro FI engine I was going to put in my old W114 coupe. It would be a nice item to honor the car I miss.
I wonder if the smaller W123 model would work on a 2.7/6 as-is or if it would need fans for traffic duty in the DC area. |
| davep |
Sep 1 2020, 09:20 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Thanks Tony. It is even available new on Pelican Parts:
https://www.pelicanparts.com/More_Info/1261...26-180-00-65-M6 |
| gms |
Sep 1 2020, 09:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
Thanks Tony. It is even available new on Pelican Parts: https://www.pelicanparts.com/More_Info/1261...26-180-00-65-M6 Cheaper Here |
| davep |
Sep 1 2020, 09:33 PM
Yes, I did see as low as $288. What are the fitting sizes?
Glenn, do you or would you use one of these? |
| JmuRiz |
Sep 2 2020, 08:15 AM
I think i saw them listed as /10 on some of the MB boards, what say you Tony?
| Mark Henry |
Sep 2 2020, 09:34 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
| Mark Henry |
Sep 2 2020, 09:43 AM
Cohline, in this pic from the bird MB forum shows a cohline fitting.
The bottom line is a standard hose fitting silver soldered on. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.tglmarketinginc.com-26-1599061422.1.JPG) |
| dr914@autoatlanta.com |
Sep 2 2020, 10:04 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you will save a lot of time and heartache buying Jim Patricks designed and tested setup. Years ago before Jim took it upon himself to make a great kit, we used an rx7 mazda cooler and then fabricated aeroquip lines, used a 911 oil cooler thermostat and the gt shroud and 916 engine grille chicken wire. Even took for some high line applications, a factory chrome bumper, cut it to gt specs and had it rechromed to match the lower gt valance
Looking for the correct front oil cooler, preferable Setrab, to mount in front. The Patrick Motorsports one is 21.5 x 4.25, so I am guessing that is the maximum size I can go. Looking for a cheaper or direct alternative rather than spend $450 on the PMS one. |
| 914Toy |
Sep 2 2020, 10:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
OzCoolingParts Pro Heavy Duty Performance Aluminum Transmission Cooler - approx 20"x 4.5". $200 - probably a good option.
| RiqueMar |
Sep 2 2020, 10:45 AM
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California
I just went through sourcing this last month, and posted the following on this site, hope this helps! Link Here - Oil Cooler Thread
Additionally, should you settle on the PMS unit, hope my photos and references on my build thread help. I see you're in La Quinta, let me know if you need any assistance. (IMG:style_emoticons/default/bye1.gif) |
| RFoulds |
Sep 2 2020, 01:22 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 861 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
[quote name='bdstone914' date='Sep 1 2020, 06:40 AM' post='2847626']
@RFoulds date='Aug 31 2020, 04:52 PM' post='2847509'] Youre on to something with the Behr 300D cooler. Dimensions check out and used on EBay under $100, even new aluminum version only $250. Much better. Thanks [/quote] I have a couple of them with the swivel fittings. They are a perfect fit and a quality Ferman made Behr cooler. Bruce [/quote] Dammit Bruce, I should have thought to call you. I found the Behr Mercedes one at FCPEuro for $190. If I didnt already have a shroud on hand, the PMS kit would have worked out better. I tried to save cash using my existing Setrab cooler, and a shroud already on hand. in hindsight, I could have used the existing cooler without a shroud anyway. |
| mb911 |
Sep 2 2020, 02:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
| brant |
Sep 2 2020, 03:51 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Fluidyne, double pass
I run a pair of them |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:58 PM |
