> Best way to remove tin bolts, Without break8ng them
Mcraneiowa
post Oct 19 2020, 06:25 PM
Is it common practice to heat the little bolts holding the tin on the engiine in order to remove them. I have been soaking them with penetrating oil. Iask this is I don’t wanna get anything too hot and damage the engine case. Looking to see what others have done as I’ve already broken one I will have to tap it out just don’t wanna have to do more if I can help it
porschetub
post Oct 19 2020, 06:49 PM
QUOTE(Mcraneiowa @ Oct 20 2020, 01:25 PM) *
Not a job for penetrant ,heat the head of the screw and let it cool ,fit large screwdriver and hit downwards with a small hammer, no movement heat again ,if the head of the screw is chewed out use large vise-grips to undo.
You will never get the case to hot with a small micro butane torch,good luck.
Gint
post Oct 19 2020, 06:59 PM
Mike Ginter
I had one engine that was a PITA to get the tin screws off. I had good luck in that instance with a cheap manual impact driver. Something like this:
https://www.homedepot.com/p/TEKTON-3-8-in-D...-2905/205674679
90quattrocoupe
post Oct 20 2020, 12:38 AM
When you put them back in, anti-seize is your friend.
AZBanks
post Oct 20 2020, 01:44 AM
QUOTE(Gint @ Oct 19 2020, 05:59 PM) *
An impact screw driver can work wonders on difficult screws.
GregAmy
post Oct 20 2020, 06:34 AM
+1 on anti-seize, and replace them with something other than those cheese heads screws...
https://914rubber.com/engine-tin-stainless-...nd-washer-set-1
Amphicar770
post Oct 20 2020, 09:37 AM
When I pulled my engine I removed all of the tins to have them powder coated. Many of the original screws required liberal use of the torch to remove. I recall the bernzomatic with MAPP gas was sufficient for most but, a few needed the acetylene torch. Did not break any.
I replaced all of the cheese head screws with stainless allen screws and also used anti-sieze. I think I picked up a bag of 100 on ebay or Amazon for cheap. I recall a small number being a different size but, the local True value had a good selection of metric, stainless allen screws.
Dobbsy
post Oct 20 2020, 11:05 AM
Region Association: England
Has anyone experienced galvanic corrosion when using Copper grease on steel studs in Aluminium. It is my understanding its something you should avoid.
IronHillRestorations
post Oct 20 2020, 11:06 AM
I. I. R. C.
QUOTE(Dobbsy @ Oct 20 2020, 10:05 AM) *
Use milk of magnesia
Dobbsy
post Oct 20 2020, 11:27 AM
QUOTE(IronHillRestorations @ Oct 20 2020, 06:06 PM) *
Searching Milk of magnesia it has lots of uses on one being a laxative, I am guessing that this product is not what you are recommending to use on your car. I do get good results searching for Aluminium anti seize grease.
Thanks for the advice
post Oct 20 2020, 02:30 PM
QUOTE(IronHillRestorations @ Oct 20 2020, 01:06 PM) *
rhodyguy
post Oct 20 2020, 02:44 PM
MM (IMG:style_emoticons/default/agree.gif) . Coating, liberally, exhaust studs makes taking the nuts off a breeze next time. Repeat shots of penetrant. Be patient. If the screw head slots are shot, use vice grips and replace the screws.
Mark Henry
post Oct 20 2020, 05:02 PM
that's what I do!
I have a oxy/propane cutting torch, not as hot as oxy/acetylene, but perfect for cars. For me worth the bother of an oxygen tank and propane is way cheaper than acetylene.
Superhawk996
post Oct 20 2020, 05:21 PM
QUOTE(Mark Henry @ Oct 20 2020, 07:02 PM) *
@Mark Henry
Acetylene has gotten expensive since that plant explosion back in 2018 that has constricted supply (IMG:style_emoticons/default/sad.gif)
Do you still use the same regulator(s) and tips or did you need new regulators to run propane? Do tell. I don't use much acetylene but my tank is getting low.
Even Argon has gone way up in last couple years with inflation + new Hazmat fees my gas supplier puts on bottles. (IMG:style_emoticons/default/sad.gif)
Mark Henry
post Oct 21 2020, 02:40 PM
that's what I do!
QUOTE(Superhawk996 @ Oct 20 2020, 07:21 PM) *
@Mark Henry
I just went to a welding supply shop and told them I wanted to convert, dude had me the kit in a second. IIRC the tip, sort of an inner tip and a jet.
This is 25+ years ago, 10 or so years ago I had to replace just the tip... I think?... But the welder supply had the stuff in stock.
BTW I go through lots of oxygen, but I get several years out of a tank of propane.
Superhawk996
post Oct 21 2020, 03:12 PM
QUOTE(Mark Henry @ Oct 21 2020, 04:40 PM) *
@Mark Henry
@Mark Henry
Thank you.
post Oct 21 2020, 07:32 PM
I. I. R. C.
QUOTE(Dobbsy @ Oct 20 2020, 10:27 AM) *
Serious on that. I got the MOM tip from a Jake Raby post. It's all I use on spark plugs, exhaust studs, etc. Jake said they used it on the plugs for jet engines.
post Oct 21 2020, 07:58 PM
I. I. R. C.
Back on topic. I too use a hand impact when I get a stubborn one. Most of the time I do OK with my largest Stahlwille metric screwdriver that has a hex shank at the top. I can lean on it pretty hard and get the torque with a wrench on the hex. FWIW, there's a difference between SAE and metric screw drivers
SKL1
post Oct 21 2020, 10:43 PM
The 914 rubber ones are nice but I guess I prefer the OEM look. Call me a purist. You can get nice new ones at McMaster Car...
Frankvw
post Oct 22 2020, 03:04 AM
working on my first 914 !
Region Association: Europe
MoM must be an American thing.....I use Ceramic Grease instead of Copper Crease. After the jar of CopperGrease was empty, I switched to Ceramic Grease. so far , so good !
- Lo-Fi Version Time is now: 2nd April 2026 - 08:37 AM
