> 914 2.0 1973, convert back to fuel injection
theghoul
post Apr 5 2021, 12:57 AM
Hi! nice forum - mainly have the front engine Porsches, but am helping a friend with a 914 2.0 he bought that had a single carb conversion, and I believe it is best to go back to the fuel injection. He has an extra motor with fuel injection but not sure it is a 2.0. Has the ECU- I know it needs to be a 13 or 14 and dont know that yet. He has the wiring and the intake tubes and injectors - any pitfalls to this job? Any info is appreciated! thanks, theghoul
Arno914
post Apr 5 2021, 03:50 AM
https://jetronic.org/en/
BeatNavy
post Apr 5 2021, 05:07 AM
Here's another resource that's 914-specific: https://members.rennlist.com/pbanders/DJetParts.htm. It will help you determine which components you have by PN and/or appearance.
If there's a single carb on there it's probably safe to assume they never cracked open the case and put a non-FI friendly cam in there.
First "pitfall' I can think of is that you really need to source the components from same year setup. While 2.0 FI D-Jet is largely the same across the years, there are a couple of significant differences. You can put a '73 2.0 D-Jet on a '74, for example, but you mainly want to ensure that key components match up together -- primarily ECU, MPS, and CHT (but also throttle body and distributor). That link above has that info. Make sure the distributor is also D-Jet compatible for the year. It needs to have the trigger points and trigger point connection.
Another thing is just making sure the individual components are serviceable. I'd consider sending out the injectors for cleaning/testing and doing individual tests on things like the MPS and CHT.
Getting the vacuum lines hooked up properly can be a little fun, too, based on the little idiosyncrasies of different parts/setups. Same thing with fuel lines. You'll need a high-pressure FI fuel pump -- either stock 3 port or simplified, new 2-port. Jeff's site has great reference info here: https://bowlsby.net/914/Classic/TechNotebook.htm
I'm sure there's more...but I think it's a worthwhile effort (hopefully). Properly functioning D-Jet is a great, reliable system, but it does take time and effort to get the gremlins out of a 50 year old setup that may have been hacked around a bit.
rick 918-S
post Apr 5 2021, 05:46 AM
Hey nice rack! -Celette
(IMG:style_emoticons/default/welcome.png) best move is to go back to FI. When I did 7 of 9 I sent the engine harness to Jeff Bowlsby and had him test and repair it. He can fix any bad or brittle wires and install all new boots. takes all the guessing out of trouble shooting any issues with the rest of the system.
burlybryan
post Apr 5 2021, 08:09 AM
Helpful info here. I'm doing the same thing to my carb converted 74 2.0 and recently acquired all the FI components from a running 74.
post Apr 5 2021, 09:52 AM
914-6 GT in waiting
If I had a four I would switch it to PMB's new FI system.
burton73
post Apr 5 2021, 11:30 AM
Senior member, and old dude
QUOTE(mepstein @ Apr 5 2021, 08:52 AM) *
Eric says this is the set up
Bob B
MikeM
post Apr 5 2021, 12:10 PM
Does anyone have a link to more info on Eric's system?
Thanks.
post Apr 5 2021, 12:20 PM
914-6 GT in waiting
QUOTE(MikeM @ Apr 5 2021, 02:10 PM) *
Thanks.
I would contact PMB. They have always been very responsive to me.
theghoul
post Apr 5 2021, 12:27 PM
All great info- thanks - will reiinspect all the parts involved - I hope the extra engine is from a 73 or 74! thanks, theghoul
- Lo-Fi Version Time is now: 2nd April 2026 - 07:43 AM
