| jaredmcginness |
May 9 2021, 02:15 PM
... ![]() ![]() ![]() Group: Members Posts: 509 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region
Hey all,
Have had a dog of a try trying to get the tail shift usable. I’ve done a lot of the typicals, but it is always very vague. Lines up nice in the garage, but once I am rolling, 2 might be 4, 3 might be 5, etc I was reading about some guys welding to add material at the tail selector. Here’s where I am at. Looks like a LOT of slop here, which I imagine translates even more to the lever. Check this video out: SHIFT SLOP VIDEO. Let me know if the video works, on mobile. Thanks! |
| Shivers |
May 9 2021, 03:42 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi, I have a 72', same setup it looks like. That movement in my opinion is not bad, and would effect the forward and back movement of the shifter. Not really side to side. I put in a short shift kit and all new bushings to replace the worn out ones. Made a big difference. Also the last bushing bracket at the end of the shifting rod, right where your video is being shot, that bracket will, after loosening the bolts/nuts will pivot to allow you to raise or lower the shifting rod end. Takes a little trial and error but you can find the sweet spot for the best shifting you will get.
| jaredmcginness |
May 9 2021, 03:46 PM
Great advice Shivers, I didn’t know that bracket at the rear had adjustment!
I will look into a short kit as well. My throw is SO long. |
| Shivers |
May 9 2021, 05:26 PM
| Rider914 |
May 12 2021, 10:35 AM
Member ![]() ![]() Group: Members Posts: 276 Joined: 13-April 04 From: Palm Beach Member No.: 1,923 |
Not a permanent solution, but I put an appropriately sized zip tie around the inner shift rod to take up the slack on my '72. It worked well and tightened up the slop.
Lo-Fi Version | Time is now: 2nd April 2026 - 12:19 PM |
