> Gas tank pads
partwerks
post Sep 24 2021, 07:56 PM
Are there any pads that go under where the gas tank sits to keep it from rubbing?
If so, any pictures of where they are placed?
post Sep 24 2021, 08:01 PM
914-6 GT in waiting
Yes, 3 pads. Sorry, I don’t have pics.
partwerks
post Sep 24 2021, 09:55 PM
http://www.914world.com/bbs2/index.php?sho...=355610&hl=
http://www.914world.com/bbs2/index.php?sho...32180&st=20
Is Scotch Brite the same as those pads you use to clean the dishes?
What about foamies? https://www.ebay.com/itm/273899372713?chn=p...d2d7278b8c4f66c
Two places on the front, and one on the back, driver's side?
partwerks
post Sep 24 2021, 10:15 PM
Looks like a pad on the DS back, two places on the front, but what about the spot on the PS back??
sholman5
post Sep 25 2021, 06:07 AM
Kraut burner
I bought the pads Lowes.
partwerks
post Sep 25 2021, 08:07 AM
QUOTE(sholman5 @ Sep 25 2021, 04:07 AM) *
I wonder if it would be better to glue them to the gas tank instead of the chassis, so there would be a seal/barrier, between the tank and the pad?
914sgofast2
post Sep 25 2021, 01:18 PM
Any type of foam pad should be avoided. They will retain moisture and rust out the tank from the outside to the inside. I am using a sheet of epdm rubber I got from Grainger Supply and cut to fit the shape I wanted. It has adhesive on one side and was glued to the body, not the tank. People also use pieces of the green scotchbrite scouring pads, but they too will retain moisture.
partwerks
post Sep 25 2021, 09:59 PM
I wonder if there would be local places that carry that EPDM material. I think roofers may use it, but would assume that is thinner?
How thick exactly does it need to be??
sixnotfour
post Sep 25 2021, 10:29 PM
I add a pad as noted in your pic.. rusty spot
partwerks
post Sep 27 2021, 06:38 PM
Which size/thickness EPDM in particular do they use for the gas tank padding?
I was thinking of about 3/16"
https://www.mcmaster.com/8610K94/
https://www.mcmaster.com/epdm-rubber/
bkrantz
post Sep 27 2021, 07:07 PM
QUOTE(914sgofast2 @ Sep 25 2021, 01:18 PM) *
I did the same, with non-adhesive neoprene rubber sheet material.
Front yard mechanic
post Sep 27 2021, 07:11 PM
I only use German pads super soft and slimAttached Image
- Lo-Fi Version Time is now: 2nd April 2026 - 11:55 AM
