> Another approach to the GT hood prop, or, any excuse to help a friend!
tygaboy
post May 25 2022, 09:41 AM
@buddyV Robert has the Getty GT replica hood and trunk lid. Lovely items, btw. HIGHLY recommended if you're looking for high quality and great fit. Anyway, he's been using a wooden dowel as a hood prop. We'd been talking about making him a proper prop ( (IMG:style_emoticons/default/lol-2.gif) ) since he installed the hood and we finally got around to it this week. Here's what we did:
I'm a fan of a prop system that "locks" in place and prevents the prop from falling out of place in the event of a wind gust, being bumped, etc. So the first thing I did is whip up a bracket that has a receiver for a pit pin.
Next, I sourced some M6 studs that are specifically designed to be bonded on - note the oversized, perforated base. Then I mixed high density adhesive filler into epoxy resin, positioned the studs and let things cure.
tygaboy
post May 25 2022, 09:45 AM
Once that was cured, I added layers of fiberglass over everything to add additional strength and to build up the surface between the studs. Hard to tell from the pics but the studs have a slightly raised area at the base and I wanted the bracket to contact all along its base.
tygaboy
post May 25 2022, 09:49 AM
Sorry for the lack of in-progress pics but...
We didn't want to pull the tank and weld on the chassis so we added a Rivnut to the center of the firewall and bolted another pit pin receiver to the outer area on the right side.
Then I welded up a prop rod out of stainless and used a left-hand threaded ball joint on one end and a rod end on the other. This allows the needed infinite adjustability so the overall length can be exactly what it needs to be and the rod can "pit pin lock" into the chassis receiver.
tygaboy
post May 25 2022, 09:52 AM
Done and done! I think it looks great and fits well with the vibe of his car. Most importantly, Robert is pleased with the result.
It was a fun little project and maybe helps give other hood prop junkies some ideas.
post May 25 2022, 10:19 AM
Resident German
Retroracer
post May 25 2022, 10:54 AM
Chris - those "designed to be bonded" studs are a good find - care to post the source pls?
Also, nice work on the strut!
- Tony
mgarrison
post May 25 2022, 11:39 AM
Chris, awesome details and incredible end result...as usual! (IMG:style_emoticons/default/pray.gif)
Any details you can share on sources for the pit pins & studs would be greatly appreciated!
Shivers
post May 25 2022, 11:47 AM
The hood won't be blown off of that by the wind. Nice job, has the "Store bought" look
mlindner
post May 25 2022, 12:32 PM
Thanks tygaboy, that is a great solution. I install a carbon fiber rod, works good and the wind has not been a issue yet but it is with a steel hood also. Thanks for sharing. MarkAttached Image
tygaboy
post May 25 2022, 12:34 PM
@Retroracer @mgarrison
I'm sure there are other suppliers as well but I usually end up at McMaster-Carr for specialty items like these. Here's everything you'll need, aside from the right-hand threaded stud for the rod end that holds the pit pin. Just cut an M6 bolt...
When sourcing the pit pin and the receiver(s) you need to work out how thick the rod end part is, and add that to the effective length of the pit pin then get the appropriate depth/length receiver. I was able to get it so the pit pin locks the rod end in place with zero slop.
Adhesive mount studs:
https://www.mcmaster.com/threaded-studs/ste...ve-mount-studs/
Pit pins:
https://www.mcmaster.com/pip-pins/t-handle-...release-pins-9/
Pit Pin Receivers:
https://www.mcmaster.com/pip-pins/surface-m...k-release-pins/
Rod ends:
https://www.mcmaster.com/threaded-rod-ends/...ype~ball-joint/
Left-hand thread ball joints with stud:
https://www.mcmaster.com/90-degree-ball-joi...joint-linkages/
Left-hand metric threaded rod:
https://www.mcmaster.com/threaded-rods/syst...tion~left-hand/
Stainless rod:
https://www.mcmaster.com/rods/multipurpose-...urement~metric/
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
tygaboy
post May 25 2022, 12:42 PM
One other minor detail. It's a bit of a hack but works great:
See the cover on the ball joint at the base? It's a bit of rubber hose that I put over a length of rod that I then put in the drill press. Spin it and use a 3" angle grinder to add a nice taper and... looks custom, no? (IMG:style_emoticons/default/shades.gif)
mgarrison
Your just too cool Chris - THANKS! (IMG:style_emoticons/default/smilie_pokal.gif)
echocanyons
post May 25 2022, 01:33 PM
The more I drive this car, the more I like this simple but elegant solution. Spring loaded and auto retracts when you lift the hood.
Thanks to the PMB team!
TRS63
post May 25 2022, 01:49 PM
Region Association: Europe
Really cool solution, thanks for sharing!
Antoine
roundtwo
post May 26 2022, 11:03 PM
Strong work fellas. (IMG:style_emoticons/default/beerchug.gif) Good to see you finished up in a day.
- Lo-Fi Version Time is now: 2nd April 2026 - 08:12 AM
