> Which 911 oil tanks for a six?, can they even be used?
DougC
post Jan 18 2005, 04:42 PM
If not, what are my other options in a nutshell..don't want to read through those long post for info that might not be there. Also, what else will I need, filler neck and lid? stainless hoses, etc?
Doug C
brant
post Jan 18 2005, 04:46 PM
None of the 911 ones will fit in the stock location.
however it has been done before... People have placed one in a different location. I've seen a pic of a rear trunk placement, although I wouldn't think that is such a great place to move weight to.
If your going to use a non stock location you can also buy a racing oil tank, and put it in the front trunk or something...
but any non-stock location is going to have its trade-offs and you will loose space or have to buy long more plumbing.
Mueller
914 Freak!
yes, it can be used, but not in the original /6 location...you have to get "creative" with how and where it's mounted (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) ...I've seen it done.....
no idea about the hoses and such....
Cap'n Krusty
Cap'n Krusty
The 914/6 oil tank fits right, no 911 one fits, AFIK. I prefer the stock oil lines. SS braided hoses are a leak waiting to happen. Look racy, though. With the tank, you'll need the filler neck, the oil filter console, and some seals, gaskets, and o-rings. Oh, a dipstick, too. HTH, The Cap'n
DougC
post Jan 18 2005, 05:06 PM
thanks for clearing that up guys..
Doug C
Trekkor
post Jan 18 2005, 08:40 PM
I do things...
Hey! (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Here's a nugget from mine...
Vellios Aluminum tank. Factory location and large capacity.
KT
Trekkor
post Jan 18 2005, 08:51 PM
I do things...
Factory location is an easy choice... All holes are marked ( almost ). (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Easy install.
KT
Dr Evil
post Jan 18 2005, 08:59 PM
Send me your transmission!
You can get the odds and ends in the resources section from Rich Johnson. Great guy.
John
post Jan 19 2005, 01:26 AM
member? what's a member?
What?
Perhaps the cheap-o ones are a leak waiting to happen, but I only use teflon lined ss braided hoses for oil lines.
I go to the hydraulic hose store and they happily make up hoses for me with proper hydraulic fittings instead of those aluminum ones I see so often.
We went with a round tank and mounted it up front (Peterson Enterprises I believe).
It even has a drain on it. (I would recommend getting the sight gauge for it)
michel richard
post Jan 19 2005, 06:27 AM
Doug,
If you're doing a conversion, but can't be troubled to read through a bunch of old posts to find information, you should make sure you have the motivation and the staying power to see your project through.
Michel Richard
914 2.2 E MFI
joea9146
post Jan 19 2005, 07:26 AM
I thought the Hydraulic hoses did not like High Heat.
Do you have Pictures of the fittings ad the Hoses you are using and other Details
like Brand Name of Hoses
John
post Jan 19 2005, 10:34 AM
I'll post a better pic when I get home tonight.
I don't have manufacturing details on the hoses.
The guys at the hydraulic stores that I visited told me they were good for the application (actually overkill). It is standard teflon lined stainless steel braided hose with steel fittings. The fittings are all swaged on to the ends of the hoses (not a DIY process). The hose assemblies are rated at something like 1500psi.
Never had a hose leak in the 18 years of track time that some of the hoses have seen.
From the prices that I have seen for the Earls hoses and fittings, the actual hydraulic lines were less expensive and professionally made up to boot.
neo914-6
post Jan 19 2005, 12:14 PM
neo life
Hey!  Here's a nugget from mine...
Trekkor,
Where'd you get this and what is a good price to pay? Are you running the 901 gearbox? Seems like 2.7's aren't too pricey so I'm thinking 6 again. My car (Bill P's) is set up for it already...
DougC
post Jan 19 2005, 01:29 PM
Michel Richard
914 2.2 E MFI
I was waiting for someone to say something like this.. I probably should have said "re-read" because I've read everything written on this subject for the last few months, atleast on this forum. Actually been researching all forms of conversions and sometimes the info starts running together in my mind, so I didn't want to go back through an 18 page thread for a simple answer. I've started jotting down six notes now.
Doug C
michel richard
post Jan 19 2005, 01:48 PM
That's allright. I'll be happy to help with your conversion !
I have found that I could buy hydraulic hose that fits the stock hose fittings. I figure that these hoses don't see hundreds of pounds of pressure, certainly not thousands, so my own view is that it's easy to overkill and overspend in this area.
These hoses don't see tons of heat either. Normal oil temp is low two hundreds, and if it goes into the three hundreds, you've got a ton of other problems, in any event.
Michel
Root_Werks
post Jan 19 2005, 03:06 PM
Village Idiot
QUOTE (Neo914 @ Jan 19 2005, 10:14 AM)
Trekkor,
I am running the same tank as Trekkor. Bought it new about 2 years ago for around $375. Sat around for another year before I got a 914 to do a conversion on. Good tank, has baffle, fits in stock location, uses later oil filter, already set up for AN fitings. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Trekkor
post Jan 19 2005, 05:14 PM
I do things...
This will hurt...It came out of your car. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
I'm running the 901 box.
KT
Jeroen
post Jan 19 2005, 06:14 PM
Region Association: Europe
anyone know if those Peterson tanks are available with 30mm metric fittings?
sixnotfour
post Jan 19 2005, 06:47 PM
http://www.petersonfluidsys.com/tanks.html
-12 to 30mm adapter needed, You could aways weld on what you want.
IronHillRestorations
post Jan 19 2005, 09:38 PM
I. I. R. C.
The only tanks I'd use would be the (priced as though they are gold plated) factory tanks or the aluminum fabricated tanks that GPR makes. The GPR tank is the lightest oil tank made for a 914-6, uses factory fitings or AN, and bolts up in the stock location. You can use all the factory tank boots, which makes for a very clean install. The factory filler neck fits perfectly too.
I think Veli-hose is out of business, which is just as well. The cast aluminum tanks have some advantages, but are heavy, and then there is lack of customer support, blah, blah. You can't use the factory boots, and they don't fit against the inner fender as well as the factory tanks, or the GPR tank. Also the factory filler neck doesn't fit right either.
Yes you can use a aftermarket "generic" tank, and many have done so sucessfully. My opinion is that in the overall scheme of a six conversion, a few hundred dollars more for a oil tank that fits right is spit on the griddle.
The dry sump system is the life blood of your six engine so be sure you do it properly.
- Lo-Fi Version Time is now: 2nd April 2026 - 01:24 PM
