> Shifter console leaking, Side shifter
r_towle
post Jan 14 2023, 01:25 PM
Custom Member
I have a side shifter that leaks at the console.
I cold drip every hour…
I bought the transmission gasket set from pelican
There is nothing in the set for the shifter console….nada
I removed the console
It looks like there is a bushing at the bottom.
Does anyone have a clue on part numbers to order to rebuild the shifter console?
It’s a 75/76 if that matters.
Rich
r_towle   Shifter console leaking   Jan 14 2023, 01:25 PM
Montreal914   Here is an exploded view of the assembly (found on...   Jan 14 2023, 02:03 PM
r_towle   Thank you! While I am there…. Do you think ...   Jan 14 2023, 02:06 PM
Montreal914   Sorry, I made a mistake!!! You are co...   Jan 14 2023, 02:20 PM
r_towle   I will take it apart and see what I need. It’s w...   Jan 14 2023, 02:34 PM
930cabman   Having the same issue and dis assembled it today. ...   Jan 14 2023, 06:09 PM
r_towle   Having the same issue and dis assembled it today....   Jan 14 2023, 06:48 PM
930cabman   Having the same issue and dis assembled it today...   Jan 16 2023, 10:33 AM
Dave_Darling   May? It will; it comes out as a unit. The rake h...   Jan 16 2023, 10:36 PM
r_towle   Btdt, no swearing required when in neutral. Got it...   Jan 16 2023, 10:54 PM
Dave_Darling   There's just the slightest possibility I was e...   Jan 17 2023, 05:06 PM
r_towle   There's just the slightest possibility I was ...   Jan 18 2023, 04:32 PM
930cabman   Yes, the shaft #13 with rake attached did come out...   Jan 17 2023, 05:34 PM
Dr Evil   Do not use the paper gasket under the console. Tha...   Jan 17 2023, 08:19 PM
r_towle   Do not use the paper gasket under the console. Th...   Jan 18 2023, 04:31 PM
930cabman   How did you remove the small oil seal from it...   Jan 18 2023, 06:29 PM
Chaznaster   Maybe use a seal puller? Runs less risk of damagin...   Jan 18 2023, 07:57 PM
930cabman   Maybe use a seal puller? Runs less risk of damagi...   Jan 19 2023, 05:54 AM
r_towle   If it’s the rubber seal I think it is from the k...   Jan 18 2023, 08:51 PM
914werke   Maybe use a seal puller? Runs less risk of damagi...   Jan 18 2023, 10:09 PM
Mikey914   Got what you need https://914rubber.com/shift-ro...   Jan 18 2023, 11:01 PM
r_towle   Ok, it is wicked cold and raw here. I really need ...   Jan 22 2023, 01:03 PM
r_towle   These   Jan 22 2023, 01:11 PM
Montreal914   Perfect opportunity to convert the shifter console...   Jan 22 2023, 01:43 PM
r_towle   Perfect opportunity to convert the shifter consol...   Jan 22 2023, 01:51 PM
930cabman   Perfect opportunity to convert the shifter conso...   Jan 22 2023, 04:33 PM
r_towle   Very slight side to side wiggle… Not enough to c...   Jan 22 2023, 09:56 PM
930cabman   "Crushed and damaged" O ring would indic...   Jan 23 2023, 05:56 AM
r_towle   It was certainly leaking from the housing due to t...   Jan 23 2023, 03:09 PM
r_towle   Drove up to my local dealer. Pet2 lists the o-ring...   Jan 24 2023, 02:44 PM
r_towle   measured the housing groove, its 2.25mm measure th...   Jan 24 2023, 03:05 PM
930cabman   I was at my local bearing house today and picked u...   Jan 24 2023, 05:46 PM
r_towle   There is no paper gasket in any diagram I have see...   Jan 24 2023, 06:31 PM
930cabman   There is no paper gasket in any diagram I have se...   Jan 24 2023, 06:59 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:40 AM
