> tall rear valence(s) questions, Need some clarification...
Speedo
post Mar 7 2023, 05:19 PM
Allow me to ramble...I have a 914-6 and one of Ben's GT3 mufflers, so either way I have some work to do to accommodate the twin barrels pointing out the back. If I had a real 6 tall valence, I would need to weld the tailpipe outlet shut and create one oblong or two symmetrical openings for the outlets. Good and bad news is that I don't have a tall 6 rear valence, so I don't need to stress about destroying a real valence to create what I need. But I do want a valence. Ferg kindly set me up with a short 4 valence and I have massaged it back to it's original shape, thinking that I might flatten the lower lip, add steel to make it a tall valence...and then decide what to do about the tailpipe exit. Before I start adding steel, I wanted to ask the wizards here what, if any, was the difference in the angle the short and tall valences tuck under the rear of the car. Is the angle/arc the same for the short and tall valences? Something tells me the arc of the short valence is more abrupt than the tall, but as I don't have a tall to measure or compare...I'm relying on you guys. Thanks for your help in advance.
Montreal914
post Mar 7 2023, 08:33 PM
If you can accept fiberglass, this is an option. I bought one a few years ago and will eventually install it on my car when done... (IMG:style_emoticons/default/rolleyes.gif) There are no holes, you make your own. (IMG:style_emoticons/default/smash.gif)
https://americaninternationalracing.com/pro...e-rear-valance/
Picture from their website:
DRPHIL914
post Mar 8 2023, 07:12 AM
Dr. Phil
QUOTE(Montreal914 @ Mar 7 2023, 09:33 PM) *
FYI,
they also show on their website that they make a replacement roof skin, so i guess a new fiberglass replacement. I wonder if it just needs the hardware mounted? it might be the only company i have seen that makes a replacement top for our cars!.
post Mar 8 2023, 09:32 AM
914-6 GT in waiting
QUOTE(DRPHIL914 @ Mar 8 2023, 08:12 AM) *
FYI,
It’s to cover a roll cage on a race car.
dr914@autoatlanta.com
post Mar 8 2023, 10:54 AM
agree, since you already have a modified muffler on your car, originality is out the window, so buy a short FIBERGLASS valance and go for it
QUOTE(Montreal914 @ Mar 7 2023, 07:33 PM) *
Speedo
post Mar 8 2023, 05:10 PM
"agree, since you already have a modified muffler on your car, originality is out the window, so buy a short FIBERGLASS valance and go for it"
I have a short valance. I want the tall valance. Hard to tell if the AIR valance pictured is short or tall.
Can anyone address the question of the inward angle/arc comparison between the short or tall valances?
eric9144
post Mar 8 2023, 05:30 PM
Assuming you have a narrow body car--there's a Patrick Motorsports deep rear valence with no cut outs. Could be the same as the AIR version, I don't know.
https://patrickmotorsports.com/products/bod...0c619&_ss=r
I have the wide body version, here it is when still in primer--Should be able to make it work with whatever you have going on (IMG:style_emoticons/default/beerchug.gif) :
Speedo
post Mar 8 2023, 07:06 PM
Eric,
Thanks for the heads up. That looks great! Would you be able to take side pictures level with the valance so I could gauge the angle/arc of the rear of the valance? Thanks in advance!
Montreal914
post Mar 8 2023, 10:29 PM
The one I got from AIR was the deep one and had no holes. Agreed the image is unclear but if you look at the right corner, you can see it is definitely taller than the short one. (IMG:style_emoticons/default/smile.gif)
Good luck with your project! (IMG:style_emoticons/default/smash.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 11:40 AM
