| Mikey914 |
Jan 23 2019, 01:49 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Grey or black $6 Will be ready next week One of the things I’ve had on the back burner for awhile. Note the ones listed in grey currently don’t match the length of the actual part I removed from the car. I believe they made the 911 version and super ended the part so one size fits all. So they would look out of place on our cars. |
| Mikey914 |
Jan 23 2019, 01:56 PM
Just need to pack up
Attached thumbnail(s) |
| Mikey914 |
Jan 23 2019, 02:45 PM
Will get listed tonight
| 914Next |
Jan 23 2019, 04:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 714 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest
| Mikey914 |
Jan 23 2019, 04:41 PM
Yes and here is the comparison between the 40 year old part and mine. Also correct texture on the vinyl part too.
| AHudson |
Feb 2 2019, 09:07 AM
Member ![]() ![]() Group: Members Posts: 55 Joined: 13-May 18 From: Alabama Member No.: 22,112 Region Association: South East States |
My 1970 -6 had a couple of these, but this is the most recent pic I can find. Engine and trans are out as we do a reseal and full clean up of engine compartment.
This car was restored by a seriously anal guy (not me!) and won two Parades in a row with it, so I'll make an assumption these are correct. This shot is at the front of engine compartment, passenger side. You can see the fuel pump connector boot unplugged. I ordered new from Sierra Madre (gray), though I later found them a couple places. Mikey do you offer gray as well? Attached image(s)
| Firstcar |
Mar 23 2019, 06:11 PM
Obsessive amateur mechanic ![]() ![]() Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
Mark, i’d Like to purchase one of these but can’t find them on either the new or the old site. Are they available yet? ![]() |
| euro911 |
Mar 24 2019, 04:43 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Oooh ... will these work on a 71 1.7L? ...
... something else to add to my cart (IMG:style_emoticons/default/idea.gif) |
| Jamie |
Mar 24 2019, 02:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,201 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Great dialogue...but questions remain: They have been documented here on several 1973 /4 cars so far...but were these provided on all/other years? D-Jet only or L-Jet too? All engine sizes? They are appropriate for /6s apparently but how were the three PN's used and how were they mounted in a /6? Original factory equipment or recall? Material - cloth, vinyl, rubber? Length/width/thickness? A pair of holes for mounting? Grommets/no grommets? The two from Pelican above look similar to but not the right color or length. Three PNs are listed...for the /6's. The strap is not present on my all original Feb.73/4, and was never present. The throttle cable is too low to be held as such on the D-Jet and ECU on Mistress. |
| mzapisek |
Apr 28 2023, 05:32 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States
My new throttle cable isn’t long enough when using the cable strap. Is there a longer cable I should be using?
| Mikey914 |
Apr 28 2023, 06:05 PM
May be a function of the maker of the cable not allowing for the strap. I will need to check, but as we are venturing into cable manufacturing, I will verify they fit on ours.
They are right here for those that need them - https://914rubber.com/accelerator-cable-sus...for-porsche-914 Attached thumbnail(s) |
| wonkipop |
Apr 28 2023, 11:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Great dialogue...but questions remain: They have been documented here on several 1973 /4 cars so far...but were these provided on all/other years? D-Jet only or L-Jet too? All engine sizes? They are appropriate for /6s apparently but how were the three PN's used and how were they mounted in a /6? Original factory equipment or recall? Material - cloth, vinyl, rubber? Length/width/thickness? A pair of holes for mounting? Grommets/no grommets? The two from Pelican above look similar to but not the right color or length. Three PNs are listed...for the /6's. not on L-jet. mine has never had one and its fairly original. secondly there is no where to affix it on an L jet, the ECU bracket is not the same as the D jet ECU bracket, different design --------. PET indicates only on 914/6 and 914 2.0 makes sense why its there on a 2.0, due to orientation of throttle body which is upright on the intake plenum? nice repro part by 914 rubber. another obscure detail for the fanatics. (IMG:style_emoticons/default/biggrin.gif) |
| r_towle |
Apr 29 2023, 12:52 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
we used to make fun of the 356 guys talking about things like this.
Well, we arrived. BTW, with having owned probably 15 or more of these..and seen many at shows....I have never ever seen this strap in place. I have no doubt it should be there....just never knew. rich |
| gandalf_025 |
Apr 29 2023, 02:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,516 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
| wonkipop |
Apr 29 2023, 04:26 PM
we used to make fun of the 356 guys talking about things like this. Well, we arrived. BTW, with having owned probably 15 or more of these..and seen many at shows....I have never ever seen this strap in place. I have no doubt it should be there....just never knew. rich (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) god help us. its a whacko detail for sure. what a world it was before zip ties? (IMG:style_emoticons/default/beer.gif) |
| rhodyguy |
May 1 2023, 12:12 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Good thread. Informative.
| dr914@autoatlanta.com |
May 1 2023, 12:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
to give the cable a smoother routing to the throttle body, we have factory ones on the shelf
Been wondering about these orange straps, I have only seen a very few. What do we know about them? What is their function? My limited info suggests they are on the 1973 cars...but were these provided on all/other years? D-Jet only or L-Jet too? All engine sizes? Original factory equipment or recall? What are these made of - cloth, vinyl, rubber? Length/width/thickness? A pair of holes for mounting? Anyone have these available or willing to repro them? I will buy one if available. @dr914@autoatlanta.com @Mikey914 @bdstone914 |
| 914werke |
May 1 2023, 12:39 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
(IMG:style_emoticons/default/confused24.gif) I have a apparently 50 yr old OE one on my car.
Looks a bit tatty but still does the job (IMG:style_emoticons/default/rolleyes.gif) |
| NARP74 |
May 1 2023, 01:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
we used to make fun of the 356 guys talking about things like this. Well, we arrived. BTW, with having owned probably 15 or more of these..and seen many at shows....I have never ever seen this strap in place. I have no doubt it should be there....just never knew. rich (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) god help us. its a whacko detail for sure. what a world it was before zip ties? (IMG:style_emoticons/default/beer.gif) This is the problem with liking a 50 year old car. We have talked about everything else already... |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:58 PM |
