| 9144me2enjoy |
Aug 2 2023, 07:57 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
Need some advice, looking at a 914 that overall structurally is in good shape except for the Rear Floorpans and Base of Inner/Outer firewall (Pics attached.) Is these repairs pretty difficult (1-10 scale) for someone thats has the skill set to weld/fabricate these areas and estimated cost if I was to have someone to do the labor? Is this something I should walk away from? There doesn’t appear to be any frame damage and the cars measurements all pull to stock specs. There is no engine/transmission which I would be replacing with either a built 2.0L or similar drivetrain. Suggestions…….hell hole and longs look good also the other troubled areas look good or have been addressed. Also one has to factor in how much my cost is starting off which is below $4500. Thoughts? Thank you
| dr914@autoatlanta.com |
Aug 2 2023, 10:13 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we virtually do these once a week, not difficult what so ever, just make sure to do a thorough job coating the welds the pans and installing the correct floor pan tar and painting and also lightly undercoating with the correct products
| 9144me2enjoy |
Aug 2 2023, 11:07 AM
George thank you for your expertise comments, appreciate it.
| Front yard mechanic |
Aug 2 2023, 12:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,439 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Passenger side long has some rot. You will need to remove the triangle to repair that portion also more than likely the firewall will need some kind of repair. Looks doable for the cost you are suggesting. Good luck
| Superhawk996 |
Aug 2 2023, 12:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Run away as fast as you can unless you enjoy metalworking as a hobby unto itself. If you pay someone to do the metal work properly - you’ll be underwater in no time at all.
That chassis is further gone than it looks $4500 is no bargain without an engine and trans/driveline There are there more complete - less intense projects listed right now on the classified. Here’s one that is reasonably close to you http://www.914world.com/bbs2/index.php?showtopic=366184 |
| mepstein |
Aug 2 2023, 12:34 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Ask George how much he charges for that repair. You might be surprised. There’s always more once you dig in.
| 9144me2enjoy |
Aug 2 2023, 12:57 PM
Expect the worse, hope for the best always seams like the best way to weigh into these ventures. The 72 mentioned that is for sale has its own problems too. I feel like the one I’m looking at has potential if it can be bought right in the $3500 neighborhood and I work on the rust issues myself. Not having a drivetrain isn’t an issue to me because I have drivetrains I can transplant into it providing I can get the rust issues resolved without busting the bank. Thanks again for your opinions based on your experiences. Appreciate it. I forwarded a message to George to get an estimate of what his shop would charge for the repairs.
| rjames |
Aug 2 2023, 02:40 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Expect the worse, hope for the best always seams like the best way to weigh into these ventures. The 72 mentioned that is for sale has its own problems too. I feel like the one I’m looking at has potential if it can be bought right in the $3500 neighborhood and I work on the rust issues myself. Not having a drivetrain isn’t an issue to me because I have drivetrains I can transplant into it providing I can get the rust issues resolved without busting the bank. Thanks again for your opinions based on your experiences. Appreciate it. I forwarded a message to George to get an estimate of what his shop would charge for the repairs. Unless there is something special about the car, $3500 for just a frame that needs a lot of work doesn't sound like a good neighborhood to be in. The one Superhawk996 linked to would be a better deal. If you already have a full drivetrain, you could sell what you didn't need and come out ahead of what it would cost you to fix and complete the rusted out one. |
| DaveB |
Aug 2 2023, 03:33 PM
Member ![]() ![]() Group: Members Posts: 173 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest
For replacing the floor boards - it's what George said.
I saw something in your picture that I wanted to point out. The frame under the hell hole behind the jacking point may need to be replaced or repaired. On mine, I ground the cover sheet metal off to find everything inside rusted. After dipping, you can see the damage from the hell hole which leads right into this area. Tap the metal around that area in the 914 and listen for the thud when you go over the area I pointed out. Sitting out in the Dalles for years ate out the 914 I picked up. It's not difficult to replace this damage if you have the time and place for it. If you can drill or punch an 8mm hole and do a rosette fill you're 90% there. Once all the paint and bondo was removed, I ordered about $4K in sheetmetal. I'll have several hundred hours into the bodywork when I'm done. I say that I'm on the extreme side of repairs, your milage may very... DaveB |
| 9144me2enjoy |
Aug 2 2023, 03:45 PM
| 930cabman |
Aug 2 2023, 03:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I would walk away
| 9144me2enjoy |
Aug 2 2023, 03:49 PM
Dave thanks for the insert thoughts! I agree with you guys 100%…..914 World family has saved me thousands of dollars in the past on potential investments and directed me in the right direction. Priceless information.
| Dustin |
Aug 2 2023, 03:50 PM
Member ![]() ![]() Group: Members Posts: 117 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
nm
| 9144me2enjoy |
Aug 2 2023, 03:51 PM
You guys have hit on a lot of good points (IMG:style_emoticons/default/agree.gif) time to walk away from this money pit, too many better candidates out there to explore. Thank you
| Superhawk996 |
Aug 2 2023, 04:07 PM
You guys have hit on a lot of good points (IMG:style_emoticons/default/agree.gif) time to walk away from this money pit, too many better candidates out there to explore. Thank you (IMG:style_emoticons/default/smilie_pokal.gif) I don’t think you’ll regret that decision. I sincerely hope that car is saved by someone. However it needs to be priced appropriately and it needs the new custodian to be someone that really enjoys metal work as its own reward. |
| 930cabman |
Aug 3 2023, 08:55 AM
You guys have hit on a lot of good points (IMG:style_emoticons/default/agree.gif) time to walk away from this money pit, too many better candidates out there to explore. Thank you Check back with the seller in a month or two. At that point see how hungry he is? maybe offer $1.k But be prepared to either dig in up to your elbows or open your wallet pretty wide |
| 914work |
Aug 4 2023, 07:54 AM
Member ![]() ![]() Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
not difficult what so ever, |
| JoeDees |
Aug 4 2023, 08:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I agree with previous comments in that replacing the floor pan is really easy, but the long and likely the suspension mount are not. I’d consider that a $1500 car.
Lo-Fi Version | Time is now: 2nd April 2026 - 11:40 AM |
