| riverman |
Feb 17 2005, 10:17 AM
Learn As I Go ![]() ![]() Group: Members Posts: 449 Joined: 18-January 05 From: Kitchener, ON Member No.: 3,466 |
I just bought an older Rod Simpson kit that had been previously installed in another car. The kit is pretty complete except for the water pump. My question is what kind of water pumps work for this installation? Do I need one with a custom housing or are there stock ones out there that work? Most of my research so far seems to indicate a Chrysler pump with a custom housing, but I would prefer a stock unit. I haven't bought a motor yet, but I'm looking at a 283.
| dakotaewing |
Feb 17 2005, 10:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region
A "stock" unit will not work, unless you want to put a big, nasty dangerous hole in your firewall. You can buy the unit you were talking about from Desert Hybrids, Renagade, Rod Simpson, or Maybe Kennedy engineering. Or you can go the electric pump route from someone like Meziere....
There are many posts on this board regarding V8 stuff - Just use the search button - Good luck with your new project ! Thom |
| BIGKAT_83 |
Feb 17 2005, 10:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States
Meziere makes a very nice compact remote mount mechanical belt driven pump. part # wp430
This is what I plan to use on my new conversion. These are priced at $300 and I suspect that the conversion company pumps made with the old mopar pumps would cost about the same. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
| skline |
Feb 17 2005, 10:40 AM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Contact Desert hybrids, Renegade hybrids, or Rod Simpson and purchase one of their units, they are all pretty much the same. They are tried and tested and all work great.
| 914GT |
Feb 17 2005, 11:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
This electric pump works beautiful. Use their water header and you have a very simple and efficient setup for less than $400. A single short hose connecting the pump to the engine. Then you can use a stock Chevy mechanical fuel pump, about $15. The DH pumps are excellent too. You might be able to buy a kit and build it yourself to save money.
| smrz914 |
Feb 17 2005, 07:02 PM
Soon to be brightening the life of the person behind you. ![]() ![]() Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
I would say that you should decide on the diameter of pipes you are running. Then choose your water pump. Renegade uses bigger line the simpson but they each have their own pump. How about some pics?
| Sammy |
Feb 17 2005, 10:24 PM
. ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
The simpson and renegade pumps were nearly identical at one time, I've heard the renegade has evolved slightly with some casting clean up and modified piping connections.
They both work just fine. Remember the key to sucess is KISS. |
| skline |
Feb 17 2005, 11:42 PM
KISS? Ok Sammy, I will bite, what is kiss? I am running a Renegade pump with a RS radiator. I did change the water flanges to match the pump, seems to work fine. |
| Aaron Cox |
Feb 17 2005, 11:45 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
KEEP IT SIMPLE STUPID |
| neo914-6 |
Feb 17 2005, 11:59 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
I'm running the opposite set up! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) According to Scott at Renegade, they improved their design by adding an inlet the shape of a thermostat housing (which it appears to be) to relieve the water pressure to the impeller. |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:51 AM |
