| Joe Bob |
Apr 4 2005, 10:48 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
I type in the static IP address .... 192.168.1.1 and I get a password protected site...
| 914GT |
Apr 4 2005, 10:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I think the default password on these is 'admin'. Leave the user field blank. |
| mightyohm |
Apr 4 2005, 10:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
The default PW depends on the model of router. It came with a manual, right? Read it!
| Joe Bob |
Apr 4 2005, 10:53 PM
What????Read the Fuching book????what a concept.... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Book doan say nutin' about drops.... |
| mightyohm |
Apr 4 2005, 10:55 PM
You live up on a hill. You probably get tons of interference. Remember that in SB you can receive SD radio stations, just to give you an idea of all the signals you are dealing with. Also offshore swept radar can be a factor. Try changing the channel like has been suggested.
| skline |
Apr 4 2005, 10:57 PM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Mike, is it an Access point or an access point router?
| bd1308 |
Apr 4 2005, 11:06 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
Z for linksys... no user, admin pass.....under front page, you will see channel...default is something but try 1 or 6 or 11
| Joe Bob |
Apr 4 2005, 11:15 PM
Admin, then admin....the help desk speaks Indian....was able to change to channel 11....will see how that works....
| Verruckt |
Apr 4 2005, 11:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
Wireless in a home is unstable. Cordless phones, baby monitors, next door neighbor haX0rs, microwave overs, etc, etc will affect the signal.
Recently purchased Linksys products ARE based on Cisco technology. If you want convenience, stick with the wireless and deal with the signal issues. If you want concistency, then buy some cat5 (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
| bd1308 |
Apr 4 2005, 11:41 PM
i have both in my room.....aeronets are B/G I believe.....i'm stickin to my argument, but i'd like to hear what you have to say in response, scott. please pm me....and we'll talk civilized....
| Joe Bob |
Apr 5 2005, 07:09 AM
It's a router....three computers are hooked up...one permanent hard wire, two wifi/hardline.... It shows it's been stable since last night when I pitched my hissy fit..... I was able to get in the admin file by throwing feces against the monitor and burning toe nail clippings..... The stooopid book was no help, the set up disc is glitchy, "admin" in both name AND password got me in when I typed in the static IP address on the tool bar.... Kind of like doing a clutch adjustment in the rain...but I didn't get my hands dirty. |
| Part Pricer |
Apr 5 2005, 07:40 AM
Believe everything I post ![]() ![]() ![]() Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Mike, Hopefully everything has worked out for you. However, despite the representations of our friends here, you should know that the Linksys routers use a common, readily available, cheap chipset for their wireless routers. The same chipset is used by many other manufacturers as well. The only thing special about the Linksys products is their firmware/software, and that is crap. If your problems haven't been eliminated, you can upgrade the firmware to some that is better and open source. Try either HyperWRT or Sveasoft. I would recommend that you try HyperWRT first. It gives you the ability to adjust transmit power as well as giving you additional wireless channels. It sounds like you have a lot of "noise" in your area. Using a channel that is unavailable in the standard Linksys firmware might help eliminate your problems. |
| Joe Bob |
Apr 5 2005, 08:07 AM
Have you tried it?
| Part Pricer |
Apr 5 2005, 09:02 AM
I have it running at a couple of my customers. I was dealing with range and noise issues at both of them and this fixed it. I don't use it myself as I don't allow any Linksys equipment into my house. (personal preference)
You could always try it and if it doesn't work out for you, you can always go back by just holding down the reset button. |
| Joe Bob |
Apr 5 2005, 09:16 AM
OK...will see how it does....what is an adequate "Non CSOB" donation amount?
Also....where is a good scanner that can be obtained to see what interference is around? I occassionally see a Belkin when searching for a signal....but not much else. I'm curious what is floating around in the air waves my area.....also professionally as I am a licensed PI. |
| bd1308 |
Apr 5 2005, 10:11 AM
yeah i forgot why i hated linksys until now.....the firmware updates/support is utter crap...cisco better get on the ball, cause if i don't get my BEFSR41 update soon I'm gonna crap in a box and mail it to them, and then run into the building with my 914 4x4.....in 4 wheel low!!! oops...did i let my latest project slip?
| bd1308 |
Apr 5 2005, 10:13 AM
Z if you mess with power/signal...read up on the FCC guidelines....they have a max power setting that is legal for home usage, and with you bein a PI, i'm sure you drive 65 down all major highways....
| Joe Bob |
Apr 5 2005, 10:19 AM
FCC...yeah right.
Same guys that allow bleed over from the local TV station to block out the LA stations that MAKES us have to have cable TV....assholes are worse than the (insert fav) agency..... Since my neighbors are such swell guys....a interefering transmission would be fun.... |
| Root_Werks |
Apr 5 2005, 10:26 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,929 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Just take a piss on it Mike, that'll fix it. Who needs a computer at home when you work on one all day at work anyway. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
| Joe Bob |
Apr 5 2005, 10:29 AM
Not all day....just the AM...I set up appointments and then go spread warmth and joy.....
Lo-Fi Version | Time is now: 2nd April 2026 - 10:44 AM |
