3 Pages V  1 2 3 >
> Clutch cable, came loose?
redshift
post Jan 6 2006, 09:28 PM
Bless the Hell out of you!
I hope I haven't destroyed my synchros double clutching for a mile... freaking shitty mechanic.
M
TROJANMAN
post Jan 6 2006, 09:58 PM
Looks nice in pictures.........
uhhhh,,,,,,isn't this garage fodder? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Lou W
post Jan 7 2006, 12:00 AM
Region Association: Spain
Have one of our mechanics look at it over in the garage. (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Pinepig
post Jan 7 2006, 12:26 AM
I used to have one that would eat clutch cables ( busted tube coming out of the tunnel ) When I had to stop I'd just slip it out of gear, and turn the car off. Time to go, put it in third and turn the key.
I put a Neal hydro clutch padal and slave in it and never had a problem again, I loved the clutch in that 914.
rick 918-S
post Jan 7 2006, 01:18 AM
Hey nice rack! -Celette
QUOTE (Pinepig @ Jan 6 2006, 10:26 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) where'd you get that? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
redshift
post Jan 7 2006, 04:35 PM
Oh my gawd... it's in the garage..
I changed cables over a week ago.. everything looks fine, except the nut on the adjustment end won't stay... it's stripped... I adjust it fine, push in... and back to square one..
SUCK ME NUT CRAP
M
r_towle
post Jan 7 2006, 04:48 PM
Custom Member
so you have a loose nut, a stripped nut, one nut that wont stay where you put it, or are you having problems with both your nuts?
I would say get some new nuts, nylock and go from there.
Rich
bd1308
post Jan 7 2006, 04:49 PM
Sir Post-a-lot
its a wierd nut....smaller than the generic 10mm nut. i think its actually the same wierd thread pitch one thats used on the rocker studs.
b
redshift
post Jan 7 2006, 05:00 PM
I can't be on both ends at once.. I heard a quiet sound... I think it may be the tube.
Can you repair a tube by jambing something in the tunnel to hold it in place so you can drive to a repair thingy?
M
Allan
post Jan 7 2006, 05:02 PM
Teenerless Weenie
Aren't you double nutting it?
bd1308
post Jan 7 2006, 05:03 PM
Sir Post-a-lot
chopsticks work great...
four of them with twist ties all over it should work
put it in angles like this
but the middle section should touch the clutch tube.
bubble gum might work either.
(IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
b
Dave_Darling
post Jan 7 2006, 05:12 PM
914 Idiot
QUOTE (redshift @ Jan 7 2006, 02:35 PM)
... the nut on the adjustment end won't stay... it's stripped... I adjust it fine, push in... and back to square one..
Did you use one of the standard 13mm wrench-size nuts? Betcha did--sounds like what happened to me when I did that.
You neet to use an M7 nut, 11mm wrench size. Two of them, tightened against each other, and that sucka won't go anywhere! I tired Nyloc, but it didn't hold well enough.
--DD
redshift
post Jan 7 2006, 05:55 PM
Gotta BE DA TUBE
Dark:45 out right now.. can you glue the tube in temporarily?
M
bd1308
post Jan 7 2006, 05:58 PM
Sir Post-a-lot
if you need to limp it to a shop, just keep it in second gear
b
redshift
post Jan 7 2006, 06:01 PM
hahahah RIGHT
M
bd1308
post Jan 7 2006, 06:06 PM
Sir Post-a-lot
Pinepig
post Jan 7 2006, 08:16 PM
QUOTE (rick 918-S @ Jan 6 2006, 11:18 PM)
I believe I ordered it fmon CB Performance back in the day, it was a clutch pedal assymbly for a sandrail.
Looked just like this one about halfway down the page.
Click me
Allan
post Jan 7 2006, 10:32 PM
Teenerless Weenie
Yer gonna get yelled at for yer avatar.
redshift
post Jan 7 2006, 10:57 PM
Me?
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
redshift
post Jan 7 2006, 11:02 PM
So, can I epoxy this thing in?
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I need to fix it to get it to the fixing place.
M
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 08:51 AM
