| dlee1967 |
Jan 26 2006, 09:31 AM
V8Lurker ![]() ![]() ![]() Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
Thanks guys.....here is the style of the new front tab. There will of course be two on each side. This is just a mock up to check the height of the bar in relation to the SE spoiler and the hitch on the car. I like the two hole option and will produce them in this fashion. There is room to move futher up with one more hole (3), but the strength is then reduced, so I think this will do it.
Don't take the looks of this mock up too seriously, as it was done in 1/4" plate for ease of fabrication. The 3/8" versions are being cut by my guy today and I will work on the jigs over the weekend. If I can rob a few minutes from work, I will draw the tabs for the other style bar. There will be two offerings.....one for the Super Beetle bar and one for the adjustable bar. Attached image(s)
| cobra94563 |
Jan 26 2006, 10:21 AM
Chris ![]() ![]() Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
Let me know when available! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| Gint |
Jan 26 2006, 06:22 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
| Allan |
Jan 26 2006, 06:45 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Lemme know when the final revision is available.
Looks like a nice product. |
| Cap'n Krusty |
Jan 26 2006, 06:48 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I have watched this thread for a while, and I need to put in my 2 cents worth. I have a Super Beetle towbar based setup much like the design here. I had to cut the tow bar tubing and rotate the tabs 180 degrees to gain ground clearance. It might be well to check that before you go too far! The Cap'n
| STL914 |
Jan 26 2006, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,195 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
It seems to me that this set up could do double duty as a tow bar mounting point and a trailer tie down point with a hitch pin secured in each bracket. What do you guys think? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
| DanT |
Jan 26 2006, 07:46 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Was thinking the same thing. Even use it for track towing the same way with the pin in place. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Cap'n Krusty |
Jan 26 2006, 08:13 PM
Not the right way top tie a car down. Accepted practice is to tie down the suspension, or better yet, the wheels. All the flat beds around here use soft straps through the wheels on every car that can accept the method. BMW insists on it for the newer cars. The Cap'n |
| dlee1967 |
Jan 26 2006, 09:07 PM
Cap'n, besides just peeing on the campfire, please post a picture of your bracket and towbar setup. (I was temped to give you the "This thread is worthless without pictures", but held off) It might be that your attachment brackets come in very low to the gound or your hitch on your vehicle is very high. I'm sure the group would like to see the details behind your modification of the SB bar. Thanks in advance for posting the pictures.
BTW. I never tie my cars down by the wheels on a trailer as the double action effect of two sets of springs on Texas roads makes for some unique handling of the trailer. Especially on a bridge on I-10 coming into Houston. The suspension on my trailer does a great job on its own. To each his own. We all have different equipment, experiences and preferences. |
| DanT |
Jan 26 2006, 11:17 PM
I always do what BMW suggests! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Isn't this method "tying down the suspension"? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
| DanT |
Jan 27 2006, 04:13 PM
David,
Any more progress or new pics? |
| dlee1967 |
Jan 27 2006, 04:32 PM
Parts are cut. I will be making a welding fixture this weekend. Soon to see finished product pics and pricing to follow.
| DanT |
Jan 27 2006, 04:41 PM
Thanks David,
I know you will come up with a nice product! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| dlee1967 |
Jan 27 2006, 05:05 PM
I now have the weldment for the DrawTite style towbar complete. (for Andrew)
| Gint |
Jan 27 2006, 08:39 PM
I'm going to need that one also. I'd rather buy a Draw-Tite than a generic super beetle unit. Thye're should be more readily available and more adaptable to other cars. |
| DanT |
Jan 28 2006, 04:55 PM
| blitZ |
Jan 28 2006, 05:27 PM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
It's the Drawtite towbar, the Ebay model? |
| Gint |
Jan 28 2006, 05:52 PM
Here's one:
Draw Tite tow bar on ebay Draw Tite is a manufacturer of towing equipment. They make hitches etc... |
| Gint |
Jan 28 2006, 06:07 PM
So you can see what a new unit would cost:
Draw Tite tow bar on etrailer.com You should also be able to buy a Draw Tite adjustable tow bar in just about any major city. |
| dlee1967 |
Jan 28 2006, 06:09 PM
That's the one! It uses 1/2" pins and has an adjustable spread on the bars. There are many other copies of this item on the market. I think that DrawTite just buys it and slaps a sticker on it. It is longer than the SB bar and has rectangular tubes. I believe it to be much stronger and more versitile. DLee
Lo-Fi Version | Time is now: 2nd April 2026 - 11:40 AM |
