> Type of oil matter?, I'm sure it's been asked 100 times..
terrymason
post Apr 27 2006, 03:42 PM
A search of the forum didn't really yield anything useful, so I'll ask:
What type of oil and how much should I use when doing my first oil change?
the auto store sold me some max life (valvaline i believe) oil (bought 2 gallons) and a maxlife filter. Does this sound good? I'm not exactly sure how much oil to put in (I heard 9.5 quarts somewhere), so I was thinking about using 2 gallons, then topping off the rest.
oh yeah, it's a 71 1.7
Any advantage to using synethic, or a blend?
Thanks guys, I'm totally new to 914s (and air cooled in general) so any tips are welcome.
Terry
jhadler
post Apr 27 2006, 03:52 PM
Long term tinkerer...
I think the guy at the parts store was not able to make the distinction between a 914 and a 911... A 1.7L 914 will typically use around 4 quarts of oil with a filter change. The 9.5 quart number is for 911 motors, which use a dry sump system, and as such, use a LOT more oil.
Weight of oil? That all depends, but a lot of folks have been happy with 20/50W. Synthetics are nice, but if your engine leaks oil, it'll leak even more with synthetic.
10/40 is good in winter, 20/50 is good in summer. Other folks may have other experience. And if someone like McMark or Raby chimes in here, I'd take their suggestions...
-Josh2
mike_the_man
post Apr 27 2006, 03:56 PM
I like stuff!
I'd also try and find a better oil filter. Bosch or Mann are my prefered filters, I'm sure others will give better suggestions.
Allan
post Apr 27 2006, 04:01 PM
Teenerless Weenie
Something like 3.7 qts. of good dino 20-50w is fine. I use Castrol.
Dump the filter and get a Mahle...
So.Cal.914
post Apr 27 2006, 04:03 PM
"...And it has a front trunk too."
I have used synthetic for awhile now, 20/50 and I have been happy with it.
(IMG:style_emoticons/default/smoke.gif)
mike_the_man
post Apr 27 2006, 04:05 PM
I like stuff!
Oh ya, I use Amsoil synthetic oil, for what its worth.
davep
post Apr 27 2006, 05:32 PM
914 Historian
Be sure you get a quality filter, the generally available stuff is not very useful at all. The German labels are certainly better. Make sure the rubber ring comes out with the old filter, the last thing you want is to have two rubber rings in place.
Fill the filter with oil first, then install it. Dump in 3 full quarts of oil, start engine to get the oil pressure light out. Shut down engine and check the level. Add more oil, from the first bottle used to fill the filter, until you get to the high line on the dipstick.
Tobra
post Apr 27 2006, 06:58 PM
I like to pull the coil wire and turn it over a few times, to circulate the oil, recheck level, top up and then start it, but I am sort of compulsive. If you are not familiar with spin on oil filter because of VWitis, put some oil on the new filter's rubber seal too.
Tom Perso
post Apr 27 2006, 07:37 PM
Crazy from the Cold...
I'm a HUGE fan of Shell Rotella T, 15W-40. It's a diesel oil, therefore having a higher zinc content. Zinc helps reduce scuffing and really helps with solid lifter motors.
Use that and a good Mann filter and you're set.
Tom
terrymason
post Apr 27 2006, 07:39 PM
Thanks everyone - I'm a Jeep guy who just got his first 914, so I'm learning as I go.
Terry
cnavarro
post Apr 28 2006, 06:29 AM
Cylinder Guru
Go read http://www.LNengineering.com/oil.html. I've been doing independed oil testing- I have 30+ oils already tested and I have another batch of 30 to test once I have some disposable income to throw at Stavely.
jr91472
post Apr 28 2006, 07:55 AM
"I'm pacing myself sergeant..."
QUOTE(cnavarro @ Apr 28 2006, 04:29 AM) *
Thanks Charles (IMG:style_emoticons/default/smilie_pokal.gif) Very interesting.
I am probably guilty of changing my oil too much.....
- Lo-Fi Version Time is now: 2nd April 2026 - 09:10 AM
