| jk76.914 |
Aug 22 2006, 02:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
So happens I just checked the compression on my '76 2.0 last Saturday. It has 850 miles since the rebuild, with stock heads and Euro 8:1 pistons. Pistons and cylinders new. Compression was 140-145 all around. Checked it with all plugs out and the throttle floored. Not sure if that's as high as it should be, but I'm not losing sleep over it yet.
Jim |
| nycchef |
Aug 22 2006, 02:40 PM
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
[quote name='Dr Evil' date='Aug 22 2006, 06:37 AM' post='757508']
I have someone offering a friend a "reacently rebuilt" TIV engine and two things stick out to me that give me pause. new info suspect engine # WWO 71101-102-cs112 top plate 071100031AX what does this tell us? |
| SirAndy |
Aug 22 2006, 03:23 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
what does this tell us? that tells us that: a. you can't read OR a1. it's not a T4 engine b. you haven't found the "914 Info" link on top of each page here yet (IMG:style_emoticons/default/biggrin.gif) Andy |
| Dr Evil |
Aug 22 2006, 04:05 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I thought that if he used the 1.7 he would need to get a different crank and rods due tot he stroke, right? I could be wrong as it has been a while.
| Dr Evil |
Aug 22 2006, 04:06 PM
Andy, be nice. Rich is still at the lower end of the curve when it comes to this site and TIV engines. (No I am not calling you stupid, Rich, just inexperienced (IMG:style_emoticons/default/wink.gif) )
We need pics of the suspect engine. |
| ptravnic |
Aug 22 2006, 04:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None
I thought that if he used the 1.7 he would need to get a different crank and rods due tot he stroke, right? I could be wrong as it has been a while. Correct, he would need to get a stock 2.0L crank & rods. They are fairly affordable. Prob ~150 for a good used set, then an additional $100 to get them balanced (along w/the other pieces - flywheel, pressure plate, etc). Then there's a new gasket set, new bearings, new push rods, new....... |
| Dr Evil |
Aug 22 2006, 04:15 PM
Ya, I sent him a list of necessity parts already. Told him to start shopping now.
I never had to get a crank and rods separate so I did not know. I always just got and used the motor. |
| Engman |
Aug 22 2006, 04:34 PM
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
But - whats the $ on the engine?
M |
| Bartlett 914 |
Aug 22 2006, 04:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
So happens I just checked the compression on my '76 2.0 last Saturday. It has 850 miles since the rebuild, with stock heads and Euro 8:1 pistons. Pistons and cylinders new. Compression was 140-145 all around. Checked it with all plugs out and the throttle floored. Not sure if that's as high as it should be, but I'm not losing sleep over it yet. Jim Just to make sure... Did you have the throttle floored as Jim suggested. If the throttle was not floored, then I think you may get lower readings. Not sure if it will make that much difference but at least some. Mark |
| Joe Bob |
Aug 22 2006, 05:02 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
who did the compression check?
Hot or cold? WOT or closed intake.....? Did you folloow up with oil in the cylinders? Did you do a leak down? 110 IS low....IF the test was done right. |
| Joe Bob |
Aug 22 2006, 05:05 PM
BTW....ANY complete 2.0 engine is a core unless it has paperwork.
It's worth 800-1000.00 |
| mihai914 |
Aug 22 2006, 05:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
[/quote]
the intake runners would get carbon how? combustion takes place inside the head, and fuel is only intorduced into the runners at the very end (Injector points at the valve) so only air is flowing thru them.... not a source of carbon (IMG:style_emoticons/default/smile.gif) [/quote] Sorry I was referring to the intake ports since I had everything apart to change all the engine seals. Everything was pretty clean, I could see the valve stems shine and the car is supposed to have around 68K miles. |
| type47 |
Aug 22 2006, 07:33 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Probably, I am in class right now so no manual here. yeah, i want my doctor to be playing with cars instead of listening.... (IMG:style_emoticons/default/biggrin.gif) and if you can get on the 914club board, you can get the manuals here's a link ... http://www.icbm.org/erkson/personal/Porsch...nuals/index.htm bookmark it now so there will be no excuses next time.... (IMG:style_emoticons/default/rolleyes.gif) |
| newto914s |
Aug 22 2006, 07:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
Last August I rehabed my top end(burnt Valve), rebuild 2.0 heads, stanless valves, and re-ringed the crappy dished bus pistons (IMG:style_emoticons/default/finger.gif) GEX.
Recently I did a compression check, hot, all plugs out, at WOT. and came up with 110 all around. It's 2 liters of displacment, so I'm guessing my low numbers are tied to those crap-ass pistons. Fairly certain the book says at least 125. Any one got some jugs they want to get ride of? Samson |
| nycchef |
Aug 22 2006, 07:50 PM
hey gang gotta love all this attention. to answer a few ? i've havent seen the engine yet. do not know who or how the comp test was done. the price is he bought a 912 engine from me for 1350 wants to give me his engine + 300. i think i can read but when i look at the 914 info at the top of the page all i see under engine # are letters. feel free to correct me if i'm wrong
| SirAndy |
Aug 22 2006, 08:03 PM
i think i can read but when i look at the 914 info at the top of the page all i see under engine # are letters. feel free to correct me if i'm wrong correct. meaning, any T4 that was meant to be in a 914 has a serial number starting with one of those letters (some have two) and then a number which is basically the count off the assembly line ... so, if your engine number does not start with one of the letters listed, the case is not a 914 T4 ... simple, eh? (IMG:style_emoticons/default/beerchug.gif) Andy PS: for instance, the 2.0L case sitting here in my living room has the serial "GA 012654", which makes the case a '73 or '74 2.0L US-Spec ... |
| Dr Evil |
Aug 22 2006, 08:10 PM
Probably, I am in class right now so no manual here. yeah, i want my doctor to be playing with cars instead of listening.... (IMG:style_emoticons/default/biggrin.gif) and if you can get on the 914club board, you can get the manuals here's a link ... http://www.icbm.org/erkson/personal/Porsch...nuals/index.htm bookmark it now so there will be no excuses next time.... (IMG:style_emoticons/default/rolleyes.gif) Dont worry man, I'll be the best gyno you ever had (IMG:style_emoticons/default/biggrin.gif) I was in a very pointless stats class. Nothing important, unfortunately (IMG:style_emoticons/default/dry.gif) Thanks for the link |
| MattR |
Aug 22 2006, 08:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Last time I did a compression check on my 2.0 I had readings in the 150-160 range. I still don't know what is inside the engine exactly but it looks mostly like everything is stock. The intake runners are so free of carbon it makes me think that the engine was rebuilt not long before the car sat for 15 years. HTH the intake runners would get carbon how? combustion takes place inside the head, and fuel is only intorduced into the runners at the very end (Injector points at the valve) so only air is flowing thru them.... not a source of carbon (IMG:style_emoticons/default/smile.gif) For future reference, you will get carbon in the intake runners from detonation. If your timing is too advanced, you'll blow exhaust gas up through the intake runners and you'll get some black goodness in your intake manifold. Yes, I've seen it. |
| Brad Roberts |
Aug 22 2006, 10:43 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Engines with a bunch of overlap will also show signs of carbon in the intake. Same as above (exhuast happening while the intake is closing)
B |
| McMark |
Aug 23 2006, 01:12 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
1.7 cranks and 1.8 cranks are the same.
For a low budget 1.7/1.8 rebuild, get 96 pistons and build a 1911. Make sure you get the correct pin height, as in buy them specifically for 1.7/1.8 66mm stroke cranks. Get 1.8 heads (remember cheap), build it and run it hard till it dies. For a low budget 2.0 rebuild, get 96 pistons for a 71 mm stroke, 1.8 heads and build. 2.0 heads will work for either engine and will add power & cost. 1.7 heads will only work with a stock 1.7 engine, all other parts are reusable. |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:19 PM |
