| echocanyons |
Oct 4 2006, 08:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,115 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
Any luck on those pictures Pete?
| horizontally-opposed |
Oct 4 2006, 09:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
Would also be in for a $200-300 kit — if the quality is top-notch.
Also curious about how well the setup will weather repeated usage over the years... factory looked at 914-6 GTs as disposable cars (much like all of their race cars, then and now). Maybe I need to research these more. But I am still VERY interested. Also, can anyone confirm the weight savings? pete |
| sixnotfour |
Oct 4 2006, 09:21 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| echocanyons |
Oct 4 2006, 09:59 PM
The link has the mechanical parts but no pictures of the pull mounting location inside the drivers compartment.
I am guessing it is the pull in this picture that is to the right of the ?hazard lights and tho the left of the ign switch. But I dont know for sure. Attached image(s)
| sixnotfour |
Oct 4 2006, 10:04 PM
pull knob can be anywhere ,most came through were the trunk pull was, as GT didnt use the trunk release.
Tangerine scream dash mounted pull; http://www.pbase.com/9146gt/image/22288927 Factory GT round black knob, hood release location; http://www.pbase.com/9146gt/image/23456222 |
| echocanyons |
Oct 4 2006, 10:23 PM
cool thank you!
| lotus_65 |
Oct 5 2006, 04:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i'm interested, sub $300.
thanks |
| davep |
Oct 5 2006, 06:59 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I may also be interested, so keep me in mind.
| fat73 |
Oct 5 2006, 08:49 AM
W9R1 ![]() ![]() Group: Members Posts: 244 Joined: 7-May 05 From: tampa,fl Member No.: 4,043 Region Association: South East States |
Does this kit eliminate the headlight switch?
Ed aka w9r1 |
| ConeDodger |
Oct 5 2006, 08:50 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
pull knob can be anywhere ,most came through were the trunk pull was, as GT didnt use the trunk release. Tangerine scream dash mounted pull; http://www.pbase.com/9146gt/image/22288927 Factory GT round black knob, hood release location; http://www.pbase.com/9146gt/image/23456222 Jeff, Does your GT use this pull system? |
| ConeDodger |
Oct 5 2006, 08:51 AM
I am in for one... Sub $300 please
| sixnotfour |
Oct 5 2006, 07:00 PM
QUOTE Jeff, Does your GT use this pull system? Yes QUOTE I am in for one... Sub $300 please I would buy another; QUOTE Does this kit eliminate the headlight switch? No you still need to turn em on. |
| 0396 |
Oct 5 2006, 07:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Count me in for two - if these are in the $2-300 range.
Thank you! |
| smdubovsky |
Oct 8 2006, 01:37 PM
Member ![]() ![]() Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
I'd take one in the ~$250 range.
SMD |
| ge9146 |
Oct 11 2006, 10:03 AM
Newbie ![]() Group: Members Posts: 47 Joined: 5-March 05 From: Western Michigan Member No.: 3,716 Region Association: Upper MidWest |
I would also be interested in one in the $200-$300 range
| PlanB |
Oct 11 2006, 11:14 AM
Newbie ![]() Group: Members Posts: 23 Joined: 5-October 04 From: Chicago,IL Member No.: 2,891 |
I am definetly interested. Please add me to your group buy follow-up list.
| jgullock |
Oct 11 2006, 11:26 AM
Newbie ![]() Group: Members Posts: 37 Joined: 19-August 03 From: Warner Robins, GA Member No.: 1,045 |
I'm in. Let me know.
| autohausdolby |
Oct 12 2006, 01:37 AM
Member ![]() ![]() Group: Members Posts: 232 Joined: 12-September 06 From: Sheffield, England Member No.: 6,821 |
Yep, interested here too (IMG:style_emoticons/default/smile.gif) But of a bummer being in the UK though (IMG:style_emoticons/default/sad.gif)
Perhaps a club shop with deposits is a good idea to sort the numbers? I suppose it'd mean a lot of responsibility for one guy (or girl (IMG:style_emoticons/default/biggrin.gif) ) though. |
| cork |
Oct 12 2006, 09:59 PM
ground zero ![]() Group: Members Posts: 49 Joined: 11-January 03 From: phoenix,az Member No.: 132 |
Let me know, I'm interested
| Qarl |
Oct 12 2006, 10:53 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I'm in for a set.
Lo-Fi Version | Time is now: 2nd April 2026 - 09:34 AM |
