> Rear window seal replacement, How to replace
warrenoliver
post Mar 4 2007, 11:17 AM
I still haven't been able to drive my new baby, but maybe in a week or two if this darn snow would go away. (IMG:style_emoticons/default/dry.gif)
I would like to replace the rear window seal on my 73 914. It is the seal on the outside at the bottom of the window. The one that is there curently, is pretty old, busted up, and brittle. I found what I think is the correct part on the Pelican website. They call it "Engine Lid Seal, Between Rear Glass and Engine Lid, 914 1.7/1.8/2.0 (1970-76), 914-6 (1970-72".
Before I order this thing, I would like to know if anyone has any tips on first, how to remove the old one without removing the rear window (IMG:style_emoticons/default/smash.gif) , and second, how to install the new one.
Thanks.
Warrenoliver
Grimstead
post Mar 4 2007, 12:04 PM
Cheaky Monkey
It's pretty easy, just pull the old seal back towards the tail lights.
I bought my new seal from PP and replaced it while the rear window was out but I don't see any reason why you couldn't do it with the window in.
Honestly though, if your window leaks or rattles at all, I would pull it as well and replace the buttle tape (this is super easy as well).
tyler
post Mar 5 2007, 12:05 PM
The right way is to have the rubber seal in place with the window out and then install the window. I've done it twice, once with butyl tape and the last time with a tube. I think the tube works better if your good at it but otherwise don't use tap that's too thick or it will be hard to compress and not look good. Also it's good to use some Frit for a border around the edge so you cover the irregular buytl appearance. There are time restrictions for the Frit/buytl to be installed.
The rear window comes in and out pretty easy (seats removed) and it needs spacers on the bottom to keep it up in place.
QUOTE(warrenoliver @ Mar 4 2007, 09:17 AM) *
Thanks.
Warrenoliver
Tobra
post Mar 6 2007, 03:22 PM
Take the window out and do it right.
There is a pretty detailed description in the classic threads, either here or on the other site. You have to pull the back pad, but it will give you a chance to clean up the rust at the bottom of it, if you have rust there
Eric_Shea
post Mar 6 2007, 07:55 PM
PMB Performance
Check here. (IMG:style_emoticons/default/agree.gif) you should pull the window and do it right. (IMG:style_emoticons/default/wink.gif)
watsonrx13
post Mar 6 2007, 08:02 PM
I followed Eric's thread and redid my rear window.... here's a link from my website....
-- Rob
alremley
post Mar 6 2007, 08:29 PM
QUOTE(watsonrx13 @ Mar 6 2007, 06:02 PM) *
-- Rob
Rob, what rear window seal did you use? I found two types available. A OEM clip on style or an aftermarket glue on. Having done the job which do you think best?
I am not inclined to remove the window because my window appears to be solid.
I am interested in your comments.
watsonrx13
post Mar 6 2007, 09:04 PM
QUOTE(alremley @ Mar 6 2007, 09:29 PM) *
-- Rob
My recommendation is the OEM clip on... As you can see from my website, I installed the window first, then the seal, but I had the engine lid off...
I hope this helps and let us know what your decisions are and how the outcome is...
-- Rob
Tobra
post Mar 7 2007, 02:39 PM
Take pictures before, during, after, just in case with the before and during part
alremley
post Mar 11 2007, 05:56 PM
Thanks for the information Rob. Got the seal yesterday. It is obvious that the engine cover must come off first, then I guess I just start chipping my old hardened gasket off and see what I've got.
warrenoliver
post Mar 11 2007, 07:12 PM
[/quote]
Rob,
Any suggestions on where to pick up the OEM seal? Looks like Pelican is no longer avialable, and AA shows several different ones with different prices. I will probably get the wrong one from them. Does anyone else sell the OEM seal?
Thanx.
Warrenoliver
alremley
post Mar 11 2007, 07:22 PM
(IMG:style_emoticons/default/driving.gif) [quote name='warrenoliver' date='Mar 11 2007, 05:12 PM' post='873534']
[/quote]
Rob,
Thanx.
Warrenoliver
[/quote]
Pelican, 914-512-319-10-m260, looks good. It has the metal bead imbedded in it so it can be pressed on just like the oem porsche. Just going to take a lot of careful patient work to install it without removing the window because you can't reach in through the window area to press it on from the inside of the car.
Jeweller914
post Jun 10 2022, 10:08 AM
Region Association: England
Hi,
Do you have to take the window out to replace the engine lid seal? I appreciate it is worthwhile if the window leaks but mine is sound and all other rubber is intact.
The lid seal is brittle and cracking and you can see the wire.
Many thanks
J
Superhawk996
post Jun 10 2022, 10:22 AM
QUOTE(Jeweller914 @ Jun 10 2022, 12:08 PM) *
Hi,
@jeweller914
No - engine lid seal doesn't require window to be removed.
Just pull off toward rear of the car. However, sometimes you'll find previous owners have "glued" them in place with various types of sealant. So it may not come off easily.
914werke
post Jun 10 2022, 10:36 AM
Unless you find NOS part you can bet you will need to use some sort of adhesive to affix the new one. The OE part used a articulated metal spine to clamp to the body, the repop units dont.
rhodyguy
post Jun 10 2022, 10:39 AM
Is the bottom of the backpad solid or deteriorated? A shot backpad backing is a sure sign of a rear window leaking at some point. You will have to remove the targa interior side pieces to get the window out.
Root_Werks
post Jun 10 2022, 12:55 PM
Village Idiot
I used this with very nice results:
https://914rubber.com/engine-deck-lid-seal-for-porsche-914
- Lo-Fi Version Time is now: 2nd April 2026 - 12:38 PM
