| 74914LE |
Mar 27 2007, 09:18 PM
Member ![]() ![]() Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Looking for a list of the Vacuum Line Size and Length for the various pieces that are used on the D-Jet on both the 1.7 and 2.0 engines. Tried a search, but came up empty. If anyone has one I would really appreciate it. Thanks
| cooltimes |
Mar 27 2007, 09:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
Looking for a list of the Vacuum Line Size and Length for the various pieces that are used on the D-Jet on both the 1.7 and 2.0 engines. Tried a search, but came up empty. If anyone has one I would really appreciate it. Thanks This might help. http://www.pelicanparts.com/914/technical_...el_diagrams.htm |
| 74914LE |
Mar 27 2007, 10:08 PM
Cooltimes, Thanks for the link, but I guess I should be more specific. What I am most interested in is the lengths for each size....
| markb |
Mar 27 2007, 10:15 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Looking for a list of the Vacuum Line Size and Length for the various pieces that are used on the D-Jet on both the 1.7 and 2.0 engines. Tried a search, but came up empty. If anyone has one I would really appreciate it. Thanks This might help. http://www.pelicanparts.com/914/technical_...el_diagrams.htm Thanks, Mike! There's one there that I hadn't seen before. I just replaced all of the fuel lines on a 73 2.0 today, and wrote down all the measurements for that (I'm thinking about putting out a "kit", if there is enough interest), maybe I should do the same for all the vacuum lines as well. |
| rigglet |
Mar 28 2007, 10:51 AM
Member ![]() ![]() Group: Members Posts: 149 Joined: 28-November 06 From: Westfield, Indiana Member No.: 7,272 Region Association: Upper MidWest |
Markb,
I would definitely be interested in both a fuel line kit and a vacuum hose kit if you put one together. I've also bee looking for a list of vacuum hoses for the 1.7. (IMG:style_emoticons/default/smile.gif) |
| 74914LE |
Mar 28 2007, 12:08 PM
For the 1.7L, I am looking for a list like:
13mm - x", y", z" 8mm - x", y" 5mm - x" 4mm - x" Thought there might be one out there. Guess I will have to get out the ruler this weekend. The material is available in town, they just charge by the foot, so want to be exact. |
| tdgray |
Mar 28 2007, 12:54 PM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
AA sells a kit... I used it. Nice quality... too spendy though.
Lo-Fi Version | Time is now: 2nd April 2026 - 06:26 AM |
