| boxstr |
Nov 22 2003, 12:27 AM
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
http://www.brentwoodrocketscience.com/engine
This might work for you, but then maybe not?? CCLIN3.2GOGO |
| redshift |
Nov 22 2003, 02:08 AM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
QUOTE(boxstr @ Nov 22 2003, 02:27 AM) but then maybe not?? CCLIN3.2GOGO I dunno... short check into the archives over at PP on the 911 board says we've all missed some real good deals.. (IMG:style_emoticons/default/smile.gif) Thanks M |
| Brad Roberts |
Nov 22 2003, 02:11 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Problem is: almost all used 3.2's need a top end rebuild. Most of them smoke with anything over 80k miles on them. Its usually just a puff at startup.. but it gest worse as time goes on.
B |
| boxstr |
Nov 22 2003, 09:25 AM
The 3.2 that I bought has , as per PO 50000 mile. I am weighing wheter to do a top end. Will that be enough, or should I dig deeper and split the case? Just want a good solid engine that does not have to be dropped again soon.
This engine ran out very strong and did not smoke on startup or driving. Advise. CCLIN3.2TOWN |
| Joe Bob |
Nov 22 2003, 11:44 AM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Hey Craig.....call me.....
| Jeroen |
Nov 22 2003, 11:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
What Brad sayzzzzz...
The original valve guides are of a too soft metal and wear out too fast (approx. 80 - 100K miles) Car starts to smoke and seriously use oil If you don't fix it fast, you're looking at a full rebuild... cheers, Jeroen |
| Brad Roberts |
Nov 22 2003, 02:56 PM
The bottom ends will go 300k miles. Do the top end while it is out.. or sell the car 30k miles from now and let someone else do it.
b |
| boxstr |
Nov 22 2003, 11:34 PM
Okay top end it is. I agree, while it is out better now than when bolted in and smokin. yeck.
Thanks all for the valued advice. CCLINCAMP914 |
| Brad Roberts |
Nov 23 2003, 05:12 AM
The best part: all the people who sell engines giving out the compression and leakdown readings... neither of which will let you know if the guides are worn or not.
Be careful buying used 3.2's B |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:20 PM |
