> The engine keeps running after I turn off the key
chris914
post Apr 29 2007, 10:34 PM
My engine keeps running after I turn it off.
My Pertronic ignition died after hooking up the adapter for the tachometer. It was working for a while. But as I was tuning the carburetors the engine stopped running and wouldn’t start again.
I disconnected the MSD and the engine still wouldn’t start. I put the points in and the engine started. Then I hooked the MSD and the engine started again. But when I turn off the key the engine keeps running
Has anyone had this problem before?
The power to the points/MSD is an original wire from the engine relay board. Should I run a separate wire from the ignition key?
post Apr 29 2007, 10:44 PM
Resident German
QUOTE(chris914 @ Apr 29 2007, 08:34 PM) *
only if you like burning your car to the ground ...
i suspect the ignition switch. you'll fry your pertronix if you leave the key in the "ON" position.
sounds like you got a faulty switch that is stuck in "ON" which would explain why the engine keeps running and why the pertronix fried ...
got another switch you can try?
(IMG:style_emoticons/default/cool_shades.gif) Andy
Gint
post Apr 30 2007, 07:21 AM
Mike Ginter
My car was doing that when I had the timing at idle very retarded. Since you were changing stuff out it's a possibility.
iamchappy
post Apr 30 2007, 07:26 AM
It all happens so fast!
Power is leaking back into the system is keeping the MSD energized, a one way diode spliced into the the blue alternator wire either before the regulator or the wire running to the alternator light in the dash should solve it.
Aaron Cox
post Apr 30 2007, 05:38 PM
Professional Tinkerer
QUOTE(iamchappy @ Apr 30 2007, 06:26 AM) *
(IMG:style_emoticons/default/agree.gif) BING BING BING... we have a winner!
McMark
post Apr 30 2007, 06:20 PM
914 Freak!
(IMG:style_emoticons/default/agree.gif) with Aaron.
ejm
post Apr 30 2007, 06:38 PM
I can see the light at the end of the tunnel
Common problem... check the MSD troubleshooting info
- Lo-Fi Version Time is now: 2nd April 2026 - 01:53 PM
