| Hammy |
Oct 16 2007, 10:09 PM
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California |
How do I do a visual test/check on fuel injectors outside the car on the bench? Any way to tell they're spraying right? I don't want to install this engine and find the injectors are crap.
Hammy Testing injectors Oct 16 2007, 10:09 PM
Twystd1 Zack,
I would send em out for testing if you REAL... Oct 16 2007, 10:54 PM
Hammy
Zack,
I would send em out for testing if you REA... Oct 16 2007, 11:04 PM
Twystd1 Theres a place in San Diego that does it cheap AND... Oct 17 2007, 12:12 AM
Hammy
Theres a place in San Diego that does it cheap AN... Oct 17 2007, 01:37 AM
orange914 have you checked the fuel injection shop on 9th st... Nov 9 2007, 10:10 PM
Spoke I'm in the same boat trying to get a FI system... Oct 17 2007, 06:53 AM
blitZ I had this place refurbish my injectors. They wil... Oct 17 2007, 07:40 AM
type11969 Has anyone ever had any luck using a modern inject... Oct 17 2007, 07:56 AM
BMartin914 You can buy an injector testing unit which will fi... Oct 17 2007, 08:21 AM
slim72914 Actron makes an injector pulser so you can simulat... Oct 17 2007, 09:42 AM
BMartin914
Actron makes an injector pulser so you can simula... Oct 17 2007, 07:27 PM
jk76.914 I've tested mine a couple of times. Generally... Oct 17 2007, 08:09 PM
jimkelly www.witchhunter.com cleans the worst looking injec... Nov 6 2007, 10:23 PM
p914 In Portland there's a place Automotive Product... Nov 7 2007, 01:46 PM
toon1
Has anyone ever had any luck using a modern injec... Nov 10 2007, 10:08 AM
type11969 What injectors work and what are the modifications... Nov 11 2007, 03:14 PM
euro911 Have any of you cleaned your injectors by dunking ... Nov 10 2007, 11:27 AM
toon1 That may work, what happens to the inj's is th... Nov 10 2007, 12:21 PM
toon1
What injectors work and what are the modification... Nov 11 2007, 04:52 PM
yarin Checkout Cuzin Performance.
http://www.cruzinper... Nov 11 2007, 07:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:25 AM |
