3 Pages V  1 2 3 >
> 914 Fuel Injector Substitutes?, Choices...
JeffBowlsby
post Dec 11 2007, 10:00 AM
I recently set out to identify possible substitute fuel injectors for stock 914s. With the interest in replacement PEFI, I thought it was important to identify any options for this important part. I have not obtained or physically tested any of the injectors below, the information is based only on published data from the internet and hard copy sources available to me.
The easiest solution is to identify identically performing fuel injectors that can be direct substitutes for the original part numbers. Direct substitutes are convenient because they can be installed into new PEFI installations or existing FI systems if original parts cannot be obtained. Criteria here include that the substitute be compatible physically for mounting purposes and identical in function/performance to the original injector. I was hoping to find new alternate injectors for <$50 each that were plentiful, but I could not find anything available.
As it turns I found information that the original Bosch pintle-style injectors are a very robust design and are the only physically similar injectors, allowing stock 914 mounting hardware and fuel/electrical connections, which for this option is important. No manufacturer makes anything similar or easily adaptable. Several different Bosch injectors are excellent matches for original 914 injector part numbers, why Bosch offers several seemingly identical injectors with different PNs I am not certain, but there are hints that the injector bodies are very similar if not identical, it’s only the attached hose that is different – short/long, straight or angled. Hoses are easily changed. A side by side comparison and testing would be important to distinguish actual differences. Don’t think that 914 injector flows are hugenormous, The original PN injectors are nicely sized and capable of supplying sufficient fuel for 914 engines with only short duty cycles, which contributes to their durability and long service life. Bosch makes several injectors with comparatively enormous flow rates much greater than 914 injectors.
Substitute identical injectors I found were all about the same price, and mostly made for Volvos and Mercedes Benz’ of the same vintage as the 914 using D-Jet fuel injection, which raises a concern. Not only are these substitute injectors no less expensive than the 914 part number, it would seem likely that at sometime in the future when Bosch decides to no longer support 914 injectors they might also drop all injectors of this design and era, so at that time, this straight substitution will not be an option. Who knows when or if that might be?
The chart below shows several possible substitute Bosch part numbers that seem to be sufficiently identical to the original 914 injectors. I found at least one source for each of them, with only a brief search.
A second solution uses physically identical injectors, but part numbers with different functional characteristics, compensating with PEFI tuning to make them work. I don’t think this is the easiest solution, but it could certainly work well. They should easily mount right up, but one problem is that these Bosch pintle-style injectors that may go obsolete. Another issue is that tuning a PEFI with these parts requires a commitment to those specific parts, or retuning using different parts in the future may be required.
Great news though…check out the injectors that are bolt-ins for the 1.8L 914, especially part number 0 280 150 114 for many VWs. I found this PN available from several sources for as little $65 new. They require electrical connector swaps (easy), but there are so many cars that use them, including newer cars than the 914 that they should be plentiful for many years to come. These injectors will require longer duty cycles, but nothing extreme.
A third option which I see as the last resort or only for very special needs is to use other suitable injectors of any physical design and functional characteristics. This is the most difficult option, promising at this point in time, little if any benefit to most owners. Newer style injectors could be selected and a PEFI could be tuned to work. Fabrication work would be necessary to configure a fuel rail and other mounting and electrical requirements, which for many is not possible or expensive in terms of time and/or cost. I perceive this to be the most expensive option in time and cost, for undetermined benefit.
Thought I would pass what information I found for reference…use it at your own risk.
Do you know of any other options?
McMark
post Dec 11 2007, 10:15 AM
914 Freak!
Wow, Jeff, that's really cool. Very interesting stuff. I can think of a few ways to make a bolt on fuel rail that doesn't require fabrication skills. If that opens up more doors, maybe we should look into that option.
rick 918-S
post Dec 11 2007, 10:36 AM
Hey nice rack! -Celette
Nice work Jeff. I used a couple of injectors from a 1984 BMW 533I in my 1.7 once in a pinch. I don't know if it caused any real problems.. it ran...
p914
post Dec 11 2007, 11:18 AM
Hey Jeff
Great info. Here's another chart of Injector part#s and stats.Attached File  fuel_injector_part_numbers.xls ( 172.5k ) Number of downloads: 2762
jimkelly
post Dec 11 2007, 11:34 AM
Delaware USA
this looks promising
http://www.914world.com/bbs2/index.php?sho...c=77265&hl=
450sel pn seems to be 57512
at www.partsamerica.com
http://www.partsamerica.com/ProductDetail....677&PTSet=A
toon1
post Dec 11 2007, 11:43 AM
Is your plan to go to a PEFI?
Jake Raby
post Dec 11 2007, 04:40 PM
Engine Surgeon
Great info..
We'll be offering (stock) intake manifolds fitted with newer model Bosch injectors with a special weld in bung in 08..
Of course the stock FI guys can't use these due to the impedence differences but it makes plenum based EFI much easier.
I'll be testing them on the dyno Thursday and Friday of this week on a RAT/SDS retrofit equipped 2056..
With these there are hundreds of injectors that will drop right in with no issue at all..
rick 918-S
post Dec 11 2007, 08:55 PM
Jake, Are your intakes larger inside as well? Otherwise maybe an adaptor could be fashioned to fit the stock bung,... just thinking out loud. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif)
Jake Raby
post Dec 11 2007, 10:01 PM
Engine Surgeon
No, these are stock runners with the bung modification made to them...
The stock 2.0 runners support my 155HP common plenum 2270-155 combo very well.
toon1
post Dec 11 2007, 10:10 PM
ALso , some newer style inj's have an O ring on the tip side that slips into a bore rather that a sandwich fit like the stock 914
Root_Werks
post Nov 24 2008, 08:48 AM
Village Idiot
I searched and found this thread with really great info on it. I have one injector on my 914 that isn't doing anything and am 99% sure it's dead. Anyone ever try the Benze Fuel Injector as a sub? Looks like a match to me.
Spoke
post Nov 24 2008, 10:08 AM
Jerry
Anyone familiar with these injectors on Ebay? They're remanufactured 4 for $120 shipped.
Ebay Injectors
Mark Henry
post Nov 24 2008, 12:44 PM
that's what I do!
QUOTE(Spoke @ Nov 24 2008, 11:08 AM) *
Ebay Injectors
1.8 Ljet injectors, not that hard to find and they flow less than 1.7 injectors...it's the 2.0 injectors that are hard to get.
Root_Werks
post Nov 24 2008, 03:31 PM
Village Idiot
QUOTE(jimkelly @ Dec 11 2007, 09:34 AM) *
I ordered just one injector for now. $50, Not bad at all. All the same specs. I report back if and how it works. If it does well, I might get 3 more to match the set? (IMG:style_emoticons/default/idea.gif)
Drums66
post Nov 24 2008, 04:35 PM
914 Rudiments
QUOTE(Mark Henry @ Nov 24 2008, 10:44 AM) *
Ebay Injectors
aren't Those 912-E injectors......Ljet on 2.0?....working off my bad memory again. (IMG:style_emoticons/default/idea.gif)
Root_Werks
post Dec 2 2008, 08:51 PM
Village Idiot
Sooooo, I got my injector today.
Root_Werks
post Dec 2 2008, 08:52 PM
Village Idiot
I don't think the injector would be made in Germany?
Root_Werks
post Dec 2 2008, 08:53 PM
Village Idiot
Check out the tip!
Root_Werks
post Dec 2 2008, 08:56 PM
Village Idiot
Other than the tip being a little different and slightly shorter, they are the same. 914 seems to run just fine now. Do I dare get 3 more?
JeffBowlsby
post Dec 2 2008, 09:51 PM
Kuhl Dan....Are these the equivalent to the 0280 150 036 injectors? The specs match 2.0L injectors and its nice to know there is an alternative. (IMG:style_emoticons/default/shades.gif)
I wonder what the significance of the tritip is? (IMG:style_emoticons/default/idea.gif)
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 06:43 AM
