| LefthandRev |
Jan 1 2025, 05:20 PM
Member ![]() ![]() Group: Members Posts: 85 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
I think I've read every Rennshift post on the forum trying to figure out WTAF is going on with my car and this installation.
Here's the quick and dirty version:
It has not been modified. I was thinking about either adding length to the front of the rod in the cabin, or removing it, drilling a new hole for the pin, and extending it forward by the inch or so that is needed to make this work... IF there's enough length to do that. I'm super annoyed by this. Attached thumbnail(s) |
| sixnotfour |
Jan 1 2025, 08:06 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
is that a 914 side model JWSTRSSDSTSN
| mepstein |
Jan 1 2025, 09:08 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| LefthandRev |
Jan 1 2025, 10:22 PM
is that a 914 side model JWSTRSSDSTSN Yea, What's pictured is a stock side shifter but the rod in the tunnel has a tail shifter cup. The stock rod would have a round shaft at the end, not a cup. Did you change it for some reason? No. I got the car this way. It's always shifted like crap. I wonder if I'm screwed here. The tail shifter cup came with the Rennshift as a way to mount to the rod. That's what I was told I needed, anyway. |
| sixnotfour |
Jan 1 2025, 10:35 PM
is that a 914 side model JWSTRSSDSTSN Yea, What's pictured is a stock side shifter but the rod in the tunnel has a tail shifter cup. The stock rod would have a round shaft at the end, not a cup. Did you change it for some reason? No. I got the car this way. It's always shifted like crap. I wonder if I'm screwed here. The tail shifter cup came with the Rennshift as a way to mount to the rod. That's what I was told I needed, anyway. who ever told that,,seems to be wrong,, https://www.pelicanparts.com/More_Info/JWST...amp;SVSVSI=0716 |
| sixnotfour |
Jan 1 2025, 10:48 PM
Gearbox/Car Type: 914 Side-Shift (Clevis attachment under shifter) ('73-'76) Attached image(s)
LefthandRev Another Rennshift Issue - 1974 Side-shift Jan 1 2025, 05:20 PM
LefthandRev
[quote name='mepstein' post='3184441' date='Jan ... Jan 1 2025, 10:37 PM
sixnotfour https://cdn.shopify.com/s/files/1/0521/8792...df?v... Jan 1 2025, 11:07 PM
VaccaRabite I'm really confused here.
Is your car a tailsh... Jan 2 2025, 06:59 AM
mepstein I have a feeling it’s just a miscommunication ab... Jan 2 2025, 07:09 AM
LefthandRev
I have a feeling it’s just a miscommunication a... Jan 2 2025, 10:13 AM
rick 918-S
I think I've read every Rennshift post on the... Jan 2 2025, 07:24 AM
mepstein I would also take some pics of the engine side fir... Jan 2 2025, 07:31 AM
LefthandRev
I would also take some pics of the engine side fi... Jan 2 2025, 10:14 AM
sixnotfour :popcorn: Jan 2 2025, 04:20 PM
sixnotfour Make sure they select...
Gearbox/Car Type: 914 Sid... Jan 2 2025, 04:28 PM
LefthandRev
Gearbox/Car Type: 914 Si... Jan 3 2025, 11:23 AM
sixnotfour Great News,, Is it Raining in Seattle?? l Lived... Jan 3 2025, 07:37 PM
Montreal914 I am sure if you contact James at JWest, he will h... Jan 5 2025, 09:24 PM
LefthandRev
I am sure if you contact James at JWest, he will ... Jan 30 2025, 12:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:39 PM |
