> Gear Choices for a 901, Looking for advice on what gears to run with a 3.0
Nick
post May 10 2006, 07:19 AM
I did some searching on this topic and didn't come up with much. I tried to find Brad's gear / speed chart but the links to it all seem broken. Basically I'm looking for some ideas on what gears I can run in the 901 that would be a better match with the 3.0. I would like to run it as a 5 speed so Ideally I'd like a first that is taller than stock and a 2nd that is taller than stock, maybe tall enough to take me to 60 mph at 6500 rpms.
Nick
Trekkor
post May 10 2006, 12:05 PM
I do things...
Mike that sounds like a great combo.
I've stayed away from the c or d first because I'll use it ( read break it ).
I really like my MSX gear box.
As long as you do the speed limit on the freeway you will run 3500-4000 rpms in 5th. ( 62-71 mph )
KT
Nick   Gear Choices for a 901   May 10 2006, 07:19 AM
dekman   Nick, I have a 3.0L(cosworth pistons 9.8:1./ E cam...   May 10 2006, 07:52 AM
dekman   Add: At 3800 my speedo says 80mph.(at 6000 it say...   May 10 2006, 07:55 AM
Dave_Darling   Realize that in a 901 box, 2nd gear is a part of t...   May 10 2006, 08:33 AM
Dr Evil   Yup, much easier and less $$ to do a 4 s...   May 10 2006, 08:42 AM
J P Stein   The GA mainshaft is relatively common....I recentl...   May 10 2006, 08:44 AM
TimT   What is the intended use of the car? For street y...   May 10 2006, 09:48 AM
smontanaro
- Lo-Fi Version Time is now: 2nd April 2026 - 10:41 AM
