| seanery |
Dec 3 2003, 07:05 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm trying to figure out how to build a good fire quickly. I just switched from wood tee pee newspaper under to wood tee pee newspaper ON the grate. It worked great!
| GWN7 |
Dec 4 2003, 01:18 PM
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Creosote is the product of incompleat combustion. It's caused by the sap in the wood mixing with the water in green wood. The water turns to steam taking the sap and other stuff up the chimney where it cools against the sides of the pipes and solidifys. If allowed to build up over time it can cause a chimney fire, which can cause a house fire or wildlands fire. It can be cleaned by either building a hot fire everyonce in awhile or running a ball and chain with wire brushes attached up and down your chimney scraping it out.
I'm planning on building a Cordwood house up at the farm. The experts in this say that winter is the time to cut your wood (after the leaves fall) The sap/moisture is the lowest in the winter. Then stack it in lengths (protected) and strip the bark off in the spring. Any sap/moisture in the logs help with the removal of the bark. Then restack for 2-3 years to let the logs dry out before cutting to building lengths. This lets the wood get down to about 10% moisture content and prevents checking and cracking of the logs. |
seanery OT-Building A Fire Dec 3 2003, 07:05 PM
Aaron Cox you forgot...brake cleaner and wood :o Dec 3 2003, 07:07 PM
sj914 i just press a little button on a remote and up go... Dec 3 2003, 07:07 PM
robby750 Go buy a box of fire starter logs. Made out of sa... Dec 3 2003, 07:20 PM
redshift Three wood components.
Cured split hardwood logs,... Dec 3 2003, 07:24 PM
GWN7 Stack your wood and use a propane torch to get it ... Dec 3 2003, 07:36 PM
URY914 Why would you want to start a fire? Dec 3 2003, 07:46 PM
Mark Henry
! I have been banned from starting fires in in the f... Dec 3 2003, 07:50 PM
nebreitling don't change your fuel lines.
i hear it works... Dec 3 2003, 07:50 PM
Qarl Newspaper crumpled, with split pine kindling, then... Dec 3 2003, 07:52 PM
redshift Here is a link to the splitter I use:
http://clie... Dec 3 2003, 08:15 PM
Aaron Cox LOL.... Dec 3 2003, 08:22 PM
GWN7 Miles,
Try putting insulation in your walls & roo... Dec 3 2003, 08:24 PM
redshift coffee+keyboard=delusional psychoid
it's gett... Dec 3 2003, 08:24 PM
Doug Leggins This old house was built in 1935 - very little ins... Dec 3 2003, 08:28 PM
Gint Dood....
Charcoal lighter fluid works GREAT! Dec 3 2003, 08:28 PM
Mark Henry
Gint You don't have to be a moron about it. Some l... Dec 3 2003, 09:02 PM
Bruce Allert
redshift
GWN7 Well I live in an igloo. 2 ft. thick walls. I can ... Dec 3 2003, 09:54 PM
campbellcj The newer construction out in these parts can... Dec 3 2003, 10:12 PM
seanery Chris,
whatayamean? (about the newer construction) Dec 3 2003, 10:16 PM
Aaron Cox my house was built w/ gas. we burn wood. a chimney... Dec 3 2003, 10:17 PM
campbellcj I could be wrong, but I recall being told it is "i... Dec 3 2003, 10:27 PM
seanery i gotcha on that one chris, embers possible floati... Dec 3 2003, 10:51 PM
campbellcj There is about 8 miles of "nothing" (brush and tre... Dec 4 2003, 12:15 AM
! Fire issues and the smoke from fire places cause n... Dec 4 2003, 12:19 AM
GWN7 You can check with your local Fire Department for ... Dec 4 2003, 01:46 AM
Bruce Allert I was brought up using no grate. Grates weren... Dec 4 2003, 08:02 AM
Lawrence Newspaper? We don't need no stinkin newspaper... Dec 4 2003, 08:09 AM
! Creosote?????
WYF, you burning RAILROAD ties agai... Dec 4 2003, 08:27 AM
Joe Ricard Yup gas in a teener + hot water heater = hotter th... Dec 4 2003, 09:31 AM
Racer I just back my Pinto up into a tree.. crude but ef... Dec 4 2003, 10:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:59 AM |
