Porsche stereo system for sale |
mr1970914 |
Oct 13 2009, 06:59 AM
I'm new here ... Group: Members Posts: 0 Joined: 24-January 09 From: New York Member No.: 9,969 Region Association: North East States |
Brand new stereo system for sale. The system includes the following items. All pyle items. $390 obo with free shipping to your door via UPS.
8-Inch Low-Profile Amplified Subwoofer (Single) 8'' Low Profile Subwoofer System Suitable for Under-seat Installations. Max Power: 600 Watt RMS Power: 300 Watt Dimension: 14. 5''(D) x 9.5''(W) x 3''(H) Weight 10.5 Lbs 4'' x 6'' 240 Watt Three-Way Speakers One Pair 4'' x 6'' Three-Way Triaxial Speaker Systems Power Handling: 120 Watts Rms / 240 Watts Max Non-fatiguing Butyl Rubber Surround 1'' High Temperature ASV Voice Coil Standard 4'' X 6'' Size Fits Oem Locations Pyle-View Series 2.5'' TFT Monitor DVD/VCD/MP3/CD-R/CD-RW/USB/AM/FM/ Receiver DVD/VCD/MPEG4/MP3/CD/CD-R/CD-RW Compatible PLL Synthesized Tuning Auto Store / Preset Scan 30 Station Memory (18FM/12AM) AM/FM-MPX 2 Band Radio (USA/Euro) Built In 2.5'' TFT Color Monitor On Screen Display Title, Time, Chapter, Subtitle Angle Treble/Bass/Balance/Fader/Volume Controls Dolby Digital Coaxial Outputs Motorized Slide Down Detachable Front Panel Selectable View Angle Anti-Shock Mechanism ESP Function PAL/NTSC Color System LO/DX ST/MO Selectors Repeat/Intro/Random Clock Function Mute Control RCA Line Out Preset EQ Subwoofer Output A/V Input A/V Output Remote Control Rear Camera Output Parking Video Input USB Conenctor USA/Europe Frequency Switch 320 Watts (4 x 80W) Dimensions: 7.24'' (W) x 2.13'' (H) x 6.69'' (D) 1/2'' 150 Watt Mylar Dome Tri-Mount Tweeter 0.5" Mylar Dome High Density Neodymium Magnet Tri-Mounting System: Flush/Swivel/Surface Ferro Fluid Cooling 12Db Crossover Network Frequency Response: 1.3Khz-22khz Spl: 92db @ 1w/1m Power Handling: 75 Watts RMS/150 Watts Max Includes Custom Mounts, Wires and Installation Hardware Attached image(s) |
jsayre914 |
Oct 13 2009, 08:21 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
hi friend,
do you have any 12" woofers i cold mount under my seat also, next to the amplifier? there is also a spare tire and tool box under the seat. i just want to make sure it will all fit. thanks again (IMG:style_emoticons/default/biggrin.gif) |
tat2dphreak |
Oct 13 2009, 09:01 AM
if these actually DO fit under the 914 seat... that would be awesome.
mr1970914 |
Oct 13 2009, 09:51 PM
if these actually DO fit under the 914 seat... that would be awesome. My 1975 914 will be done from the body shop in a few weeks. So I have not had the time to check the seat clearance yet. But I think the clearance is 3.5" from the floor to the bottom of the seat. The last time I measured I think the seat was at least 20" across. And 22" from the tip of the seat to the backpad. But if you could remeasure I would really like to know. Thanks |
mr1970914 |
Oct 13 2009, 10:04 PM
hi friend, do you have any 12" woofers i cold mount under my seat also, next to the amplifier? there is also a spare tire and tool box under the seat. i just want to make sure it will all fit. thanks again (IMG:style_emoticons/default/biggrin.gif) I have a ultra slim 12" design that just might work for you. Here are the specs for you. 12'' 1200 Watt Ultra Slim DVC Subwoofer 12'' High Quality Poly Mica Cone Butyl Foam Surround Dual 2.5'' High Temperature Kapton Voice Coil Independently Fused 20 Amp Speaker Terminals 75 Oz Magnet Structure Power Handling: 600Watts RMS/1200 Watts Peak Frequency Response:28 Hz - 2.2K Hz Impedance (Per coil) : 4 Ohm Fs:29.1, Qms:4.08, Qes:0.44, Qts:0.396, Vas (L)102.18 Efficiency: 92 dB Overall Diameter: 12.6'' Mounting Depth: 3.28'' Includes Installation Template Attached image(s) |
RJMII |
Oct 13 2009, 11:23 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
if these actually DO fit under the 914 seat... that would be awesome. My 1975 914 will be done from the body shop in a few weeks. So I have not had the time to check the seat clearance yet. But I think the clearance is 3.5" from the floor to the bottom of the seat. The last time I measured I think the seat was at least 20" across. And 22" from the tip of the seat to the backpad. But if you could remeasure I would really like to know. Thanks You should get some pics of what the body shop is doing to it. =o) Did it have hell hole issues? Pictures, man! start a build thread, even if someone else is doing the body work. We like to see! (oh, and the amp/sub combo won't fit under the seat, the rails get in the way, along with the pivot arc that is under there... If you'd really like to make a setup interesting to look at, check out A&P's center sub console along with their speaker pods and do a configuration that will help boost Morph and Spectra's sales as well by offering speakers that will compliment the fiberglass products that are already in production) |
mr1970914 |
Oct 14 2009, 05:19 PM
[quote name='RJMII' date='Oct 14 2009, 12:23 AM' post='1225667']
[quote name='mr1970914' post='1225645' date='Oct 13 2009, 09:51 PM'] [quote name='tat2dphreak' post='1225388' date='Oct 13 2009, 10:01 AM'] if these actually DO fit under the 914 seat... that would be awesome. [/quote] My 1975 914 will be done from the body shop in a few weeks. So I have not had the time to check the seat clearance yet. But I think the clearance is 3.5" from the floor to the bottom of the seat. The last time I measured I think the seat was at least 20" across. And 22" from the tip of the seat to the backpad. But if you could remeasure I would really like to know. Thanks [/quote] You should get some pics of what the body shop is doing to it. =o) Did it have hell hole issues? Pictures, man! start a build thread, even if someone else is doing the body work. We like to see! (oh, and the amp/sub combo won't fit under the seat, the rails get in the way, along with the pivot arc that is under there... If you'd really like to make a setup interesting to look at, check out A&P's center sub console along with their speaker pods and do a configuration that will help boost Morph and Spectra's sales as well by offering speakers that will compliment the fiberglass products that are already in production) Thanks but what is A&P's? |
jsayre914 |
Oct 14 2009, 05:24 PM
QUOTE Thanks but what is A&P's? a member here sells really cool custom fit stereo stuff appereance and performance. look in the member vendors section |
RJMII |
Oct 14 2009, 05:45 PM
http://www.914ap.com/
is their website. got a link to your build thread? did get some pictures from the body shop? I'll go get some pics of my seat, so you can see why nothing fits under them. |
racerbvd |
Oct 16 2009, 11:17 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Are you open to ant trades?? Do you happen to have a double din Nav system as well??
mr1970914 |
Oct 22 2009, 06:08 PM
Are you open to ant trades?? Do you happen to have a double din Nav system as well?? Sorry I have been working and just have not been able to get online. But to answer your question, I do have a few nav double din units. Most of my units are priced well under $500.00. Once again sorry for the delay in response to you. |
racerbvd |
Oct 22 2009, 07:08 PM
What brand are they??
Any Blue Tooth ones??? are you open to any trades??? Thanks, |
mr1970914 |
Oct 24 2009, 07:08 PM
What brand are they?? Any Blue Tooth ones??? are you open to any trades??? Thanks, Yes it is blue tooth, and the brand is pyle. I have a demo unit for sale for 250. I never used it except for pictures Pyle-View Series Double Din Touch Screen 7'' TFT-LCD Monitor w/DVD/CD/MP3/AM/FM/Bluetooth Details 7'' 16:9 Wide Screen TFT-LCD Monitor Displays Touch Screen Compatible DVD/MP3/VCD/CD/CD-RW Compatible AM/FM Tuner Auto Memory Store/Preset Scan 30 Preset Stations (18FM/12AM) On Screen Display Multi System (NTSC/PAL Selectable) 4 Channel RCA Pre-Amp Output Electronic Volume/Balance/Bass/Treble/Fader Control Max Output: 4x80 Watts Rear Monitor Video Output Parking Video Input Full Function Wireless Remote Control Attached image(s) |
tat2dphreak |
Oct 27 2009, 08:59 AM
I measured over the weekend, I don't see how any sub could fit under the seat, but I have thought about building a slim truck-style box for behind the seat at the butt-corner, that might fit.
racerbvd |
Nov 4 2009, 11:06 PM
Did you get my PM???
Lo-Fi Version | Time is now: 17th May 2024 - 09:32 PM |
