Targa trunk clips, cleaning |
Ian Stott |
Oct 14 2009, 04:44 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Found 2 clips for the targa roof in my parts box, both have quite a bit of paint on them. I wanted your opinions on what to use for cleaning them up so I don't ruin them with paint thinner!
Ian Stott Moncton Canada |
dr914@autoatlanta.com |
Oct 14 2009, 04:50 PM
914 Guru Group: Members Posts: 7,841 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,466 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Try WD40 first.
Ian Stott |
Oct 14 2009, 04:54 PM
Thanks guys, I'll try the WD 40 first as I don't have any aircraft stripper.
76-914 |
Oct 14 2009, 05:00 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Found 2 clips for the targa roof in my parts box, both have quite a bit of paint on them. I wanted your opinions on what to use for cleaning them up so I don't ruin them with paint thinner! Ian Stott Moncton Canada I'd be surprised if the paint stuck. I think the clip is of some phenolic material. Anyway, use some plastic bladed utensil or if you have some oak or other hardwood you can make a wedged piece and scrape with that. As long as you use a material that is <= the softness of the clip. I've scrapped a lot of aluminum with wood wedges "sharpened" on my sander and never scratched it. |
Phoenix-MN |
Oct 14 2009, 06:15 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Soak them in Simple Green concentrate, the paint just blisters/peels off.
Lo-Fi Version | Time is now: 9th May 2024 - 02:43 PM |
