Tire pressure |
Tire pressure |
Geezer914 |
Oct 16 2009, 02:16 PM
Geezer914 Group: Members Posts: 1,396 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Running 205/60/15 tires. What tire pressure are you using?
Cupomeat |
Oct 16 2009, 02:20 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
I run the same size and run 29psi cold.
Front and back. |
PeeGreen 914 |
Oct 16 2009, 02:42 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Is this just a daily driver? If so just put in 32PSI and call it good. If you are doing track or AX you're going to have to tell us what tires you're using, how much your car weighs, if it is a four or six, and then we can get a little etter idea.
Geezer914 |
Oct 16 2009, 02:48 PM
Just a daily driver with a little spirited driving
Ian Stott |
Oct 16 2009, 02:54 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I'm running on 195/60 Dunlops and 30 PSI (cold) all the way around seems to be best. I could feel the difference when I went to 32 PSI, not bad but just a little harder on the bumps, it is cooler up here so that could make a difference. I guess as long as you are getting a proper contact patch and you don't have uneven wear then you are real close to optimum. Grip/traction depends so much on rubber compound type and tread design that if you are experimenting, what seems best for you and your driving style can't be all wrong. I personally like my tires to have a little give, maybe because I have to contend with more potholes that others!
Ian Stott Moncton Canada |
PeeGreen 914 |
Oct 16 2009, 03:51 PM
If you are wanting to have them at the optimum tire performance the best thing to do is to look at the scrub on your tires. After a nice twisty drive look to see how far the tires are rolling to the side.
messix |
Oct 16 2009, 04:19 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i've got about that size and i'm running 26lb
Shade Tree |
Oct 16 2009, 06:09 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I have 205/60/15 BFG G-force.....28psi all around.
Lo-Fi Version | Time is now: 9th May 2024 - 09:06 PM |
