It seems my fecal touch continues...., Now my heat exchanger cracked inside. |
Jakeodoule |
Oct 16 2009, 10:11 PM
Member Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
After getting my used gearbox in and going for a nice long drive. It started sounding bad.. It sounds like shit and if you turn the heat on you get dizzy and then sleepy (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/yellowsleep[1].gif)
I figured I just had an exhaust leak or a bolt came loose. But after inspecting I found no bolts loose, and the heat exchangers and heater ducts are all sooty. Fired it up without the J pipe and the exhaust comes out the exchanger... Can those be repaired? Anyone had any luck taking them apart and welding up the pipe? Then re welding the SS cover back together? I think this car hates me. All I ever did to it was restore it after it sat for 10 plus years..... |
dakotaewing |
Oct 16 2009, 10:19 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
After getting my used gearbox in and going for a nice long drive. It started sounding bad.. It sounds like shit and if you turn the heat on you get dizzy and then sleepy (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/yellowsleep[1].gif) I figured I just had an exhaust leak or a bolt came loose. But after inspecting I found no bolts loose, and the heat exchangers and heater ducts are all sooty. Fired it up without the J pipe and the exhaust comes out the exchanger... Can those be repaired? Anyone had any luck taking them apart and welding up the pipe? Then re welding the SS cover back together? I think this car hates me. All I ever did to it was restore it after it sat for 10 plus years..... Jake - What type heat exchangers do you have..??? Varies by motor... |
Jakeodoule |
Oct 16 2009, 10:29 PM
[/quote]
Jake - What type heat exchangers do you have..??? Varies by motor... [/quote] The car is a 76 2.0 But I have 74 SS exchangers I think. They have the 2 pipes out the back that connect with the muffler. The muffler flange has 3 bolts. |
tradisrad |
Oct 16 2009, 11:26 PM
those are the 1.7/1.8 heat exchangers. I think they have the same diameter as the 2.0 HEs, but they kick up top meet the muffler. The 2.0 are straight.
IronHillRestorations |
Oct 17 2009, 07:02 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Those heat exchangers are now officially JUNK! Do not repair them!!!
Dr Evil |
Oct 17 2009, 07:10 AM
Dont repair. You can get another set pretty easily. Dont die.
SLITS |
Oct 17 2009, 08:55 AM
Which side has the leak?
Jakeodoule |
Oct 17 2009, 09:08 AM
SLITS |
Oct 17 2009, 09:43 AM
SLITS |
Oct 19 2009, 04:11 PM
Ok, I have a driver's side SS heat exchanger ... If you need it .... PM me.
Lo-Fi Version | Time is now: 9th May 2024 - 05:30 AM |
