is this my Auxiliary Air Regulator |
oldschool |
Oct 16 2009, 11:04 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
is this the Auxiliary Air Regulator?
Cap'n Krusty |
Oct 16 2009, 11:07 PM
I dunno if it's yours, but it's SOMEBODY'S. The Cap'n
tradisrad |
Oct 16 2009, 11:23 PM
yup, that is it. Does it work?
oldschool |
Oct 17 2009, 12:25 AM
yup, that is it. Does it work? Ok when I put power and ground it should it close or open? (IMG:style_emoticons/default/confused24.gif) |
ejm |
Oct 17 2009, 05:04 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
When powered up it will take a few minutes to close.
Dr Evil |
Oct 17 2009, 07:12 AM
It works best when installed (IMG:style_emoticons/default/wink.gif)
tradisrad |
Oct 17 2009, 10:47 AM
it does work best when installed.
Apply 12V to the wire and ground out the base. There is a heater (resistance wire) inside that heats up and closes the valve. I have also heard/read that if the wire is broken the engine can get warm enough to close it, but not as fast as the heater inside. Mine works and it makes a difference on the cold starts. I live in the SF Bay Area and like you we have moderate tempatures and the valve still helps. |
Lo-Fi Version | Time is now: 10th May 2024 - 10:26 AM |
