backdating bumpers question |
rfuerst911sc |
Oct 18 2009, 07:20 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a 1975 chassis that I'm backdating the bumpers to early style. I have the new bumper holes drilled no problem. The question I have is regarding the front bumper " lip " that I guess I have to remove ? This " lip " is where the ugly rubber cover slid over. So first question is I do have to remove this lip correct ? Assuming I do I believe I need to use a spot weld bit to drill out the spot welds ? I've never used one of these can someone give me a quick walk thru on these ? Is it as simple as drilling them out ? I know I should " search " but I'm at work most of today and they frown on too much 914 content (IMG:style_emoticons/default/biggrin.gif) .
Sleepin |
Oct 18 2009, 10:49 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I just trimmed mine off with a 3" cutting wheel.
greenie |
Oct 18 2009, 01:25 PM
Senior Member Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest |
I have a 1975 chassis that I'm backdating the bumpers to early style. I have the new bumper holes drilled no problem. The question I have is regarding the front bumper " lip " that I guess I have to remove ? This " lip " is where the ugly rubber cover slid over. So first question is I do have to remove this lip correct ? Assuming I do I believe I need to use a spot weld bit to drill out the spot welds ? I've never used one of these can someone give me a quick walk thru on these ? Is it as simple as drilling them out ? I know I should " search " but I'm at work most of today and they frown on too much 914 content (IMG:style_emoticons/default/biggrin.gif) . I'm also backdating a 75... Yes you need to remove the lip. I bought a spotweld removal tool, about $15.00. You center punch the spotweld so the pilot on the tool doesn't walk, then just drill through the attached piece you want to remove. Only drill to the point of breaking out the piece from the weld, you will be left with a spotweld slug you grind off. Simple as pie. (IMG:style_emoticons/default/beerchug.gif) |
messix |
Oct 18 2009, 01:49 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i did mine in a hotel parking lot with a 3" cut off wheel.
rfuerst911sc |
Oct 18 2009, 03:15 PM
I went to Harbor Freight and bought a spot welder cutter/bit for $4.99. Worked great but I got a little aggressive on some of them (IMG:style_emoticons/default/dry.gif) . Anyway I got the lip off and I'm moving forward with the bumper install. Thanks guys (IMG:style_emoticons/default/beer.gif)
Mikey914 |
Oct 18 2009, 07:24 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The rear bumper also has a suport that welds onto the body for the center above the licence plate. I can produce mine with out the mount if you don't want it.
Sleepin |
Oct 18 2009, 07:31 PM
The rear bumper also has a suport that welds onto the body for the center above the licence plate. I can produce mine with out the mount if you don't want it. That is good to know! When I order my rear pad from you I will be sure to specify. I am currently running mine without a support. |
Mikey914 |
Oct 19 2009, 01:44 AM
The suport still runds across the other two corneres, it just dosen't have a mounting stud, but I think you got the idea.
oldschool |
Oct 19 2009, 03:32 AM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
The suport still runds across the other two corneres, it just dosen't have a mounting stud, but I think you got the idea. So to back date what do I need (IMG:style_emoticons/default/welder.gif) and does any on have some photos of the work. I also have a 75 O wait are we talking 914 or 911 (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 08:02 AM |
