Engine Almost Ready for Install, Put the SS HEs on today |
EdwardBlume |
Oct 18 2009, 05:38 PM
This engine is close to being ready for install. 2056 with LSD 901. Today, I took off the header stub pipes to the heads and installed Stainless Steel Heat Exchangers.. The left side was tough to get on... but with some persistence I was able to squeeze it on...
I did notice oil seeping through the taco plate and some around the oil filter, but its not enough to leave a drip. Here's some picts... Attached thumbnail(s) |
VaccaRabite |
Oct 18 2009, 06:06 PM
Why are you going with SSI's over a header?
Zach |
914Sixer |
Oct 18 2009, 06:35 PM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Looking good !!!!
EdwardBlume |
Oct 18 2009, 09:53 PM
EdwardBlume |
Oct 18 2009, 09:54 PM
Notice in the first pic how hard the engine mount bar is bent forward... is that OK?
rick 918-S |
Oct 18 2009, 10:13 PM
Hey nice rack! -Celette Group: Members Posts: 20,451 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
tat2dphreak |
Oct 18 2009, 10:25 PM
Notice in the first pic how hard the engine mount bar is bent forward... is that OK? (IMG:style_emoticons/default/blink.gif) I'm going to have to say "no", I'd try to find another one. you might be able to bend it back, but I'd be afraid of it ruining the temper... WTF did you hit? |
hot_shoe914 |
Oct 18 2009, 10:30 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
This engine is close to being ready for install. 2056 with LSD 901. Today, I took off the header stub pipes to the heads and installed Stainless Steel Heat Exchangers.. The left side was tough to get on... but with some persistence I was able to squeeze it on... I did notice oil seeping through the taco plate and some around the oil filter, but its not enough to leave a drip. Here's some picts... Isn't that the motor you were supposed to send me? And WTF you need a heater for, you live in sunny California! (IMG:style_emoticons/default/WTF.gif) |
TravisNeff |
Oct 18 2009, 10:37 PM
You can bend those engine bars pretty easy. I put mine in a vice (right at the bend), climbed up on my table and bent it straight from the opposite end.
JazonJJordan |
Oct 18 2009, 11:18 PM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
Several 914 books state that works fine for the stockish /4s.
I have to do one of mine also. |
jimkelly |
Oct 19 2009, 07:03 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
mark that fan for TDC - real good - before you install the assy.
EdwardBlume |
Oct 19 2009, 09:09 AM
Notice in the first pic how hard the engine mount bar is bent forward... is that OK? (IMG:style_emoticons/default/blink.gif) I'm going to have to say "no", I'd try to find another one. you might be able to bend it back, but I'd be afraid of it ruining the temper... WTF did you hit? Its from 504, but I'm wondering if perhaps the solid rear motor mounts and the extra torque of the engine bent it. The bar doesn't look rusty or distressed, just bent... I do have an extra 2.0 engine bar to use... Good advice. I'll make sure the TDC mark is clear. |
EdwardBlume |
Oct 19 2009, 09:13 AM
This engine is close to being ready for install. 2056 with LSD 901. Today, I took off the header stub pipes to the heads and installed Stainless Steel Heat Exchangers.. The left side was tough to get on... but with some persistence I was able to squeeze it on... I did notice oil seeping through the taco plate and some around the oil filter, but its not enough to leave a drip. Here's some picts... Isn't that the motor you were supposed to send me? And WTF you need a heater for, you live in sunny California! (IMG:style_emoticons/default/WTF.gif) Ha ha. This motor is a bit more $$$ and HP. How's your 2.0 doing? Heat isn't for me... although we are a little more high maintenance here in CA. |
rhodyguy |
Oct 19 2009, 09:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i bet the bar will be more verticle when you get it off the dunage spacing it up on the funiture dolly. prob flexing the front mounts.
hot_shoe914 |
Oct 19 2009, 10:49 PM
This engine is close to being ready for install. 2056 with LSD 901. Today, I took off the header stub pipes to the heads and installed Stainless Steel Heat Exchangers.. The left side was tough to get on... but with some persistence I was able to squeeze it on... I did notice oil seeping through the taco plate and some around the oil filter, but its not enough to leave a drip. Here's some picts... Isn't that the motor you were supposed to send me? And WTF you need a heater for, you live in sunny California! (IMG:style_emoticons/default/WTF.gif) Ha ha. This motor is a bit more $$$ and HP. How's your 2.0 doing? Heat isn't for me... although we are a little more high maintenance here in CA. She is still sitting at the shop waiting to be completed. Yes, she will have heat but my other 2 still won't have it. |
Lo-Fi Version | Time is now: 11th May 2024 - 03:15 AM |
