Please help/ need advice, Rocker- Rust |
ILM914 |
Oct 18 2009, 06:09 PM
Member Group: Members Posts: 96 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi All: I am taking my car apart and have found some rust holes along the bottom of the inner Rocker panel inside the car. They are about an inch and some smaller. On the same side there are some small holes in the floorpan that I think can be treated and sealed with POR 15 which I plan to use throughout the car. I also found water around the Pedal cluster, where is that coming in from? Anyway, any advise on this is greatly appreciated. I am trying to not go through the whole cut the entire rocker/s out and weld in new one's until the car frame gets really bad. Right now the car seems pretty structurally sound. Perhaps I can cut out a little more around the rust to give me getter acess to treat inside the rocker, then weld sheet metal or fiberglass patch the opening? Or maybe just leave it open?
Oh there is also a small rust hole all the way through the driver side sail panel under where the side vinyl sticks on. I can't get to the inner part to treat it with POR-15, just the outside. Any sugestions on the best way to treat this area? Thank you for the help, Joe |
914Sixer |
Oct 18 2009, 06:39 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Most of your questions can be answered in the classic threads about doing each of the different rust repairs. Water usually comes in from bad gaskets including the top, front windshield, rear window.
Oct 18 2009, 07:03 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I can't get to the inner part to treat it with POR-15 POR-15 is NOT a rust treatment ... (IMG:style_emoticons/default/shades.gif) All it will do is seal the rust. For a while. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
ME733 |
Oct 19 2009, 10:32 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) .The lead in to.......Water at the foot pedal cluster.....(referance is my car is a 1973)... upon hand washing my car , that has always been garaged, ...I was looking for pooled water areas ,,,(anywhere)..to assist me in finding rusty areas, or , problem areas or places that needed attention when drying the car.....I noticed under the front hood, drivers side, outtermost corner of the upper sheetmetal, right at and above the inner fenderwell ....a depression....and right above it were two open holes to the inner fenderwell.( drivers side),..the standing dusty water clued me in to how deep this "puddle" was and how much dirt, dust, and grime had built up over the years... THIS AREA is right above and just offset slightly to the left of the pedal cluster.(again this is the inner trunk sheetmetal that makes up the front firewall.)...I COULD see that if this area were to be ignored and a pinhole or rust hole were to develope ; water would drip right toward the left side of the pedal cluster......In my case , even tho the rubber trunk seal is good, water came in from INSIDE the left front fenderwell ( I washed the car all over ,from top to bottom)......from the damn holes, which were factory placed.( maybe for airconditioning??)....anyway...this is an area to check as I can see it could be a rust problem , and would put water into the drivers compartment if not recognized...I cleaned up the area down to the paint...(no rust).. plugged the holes with rubber gromets, and a generious coating of black silicone sealant)... (IMG:style_emoticons/default/popcorn[1].gif)
ILM914 |
Oct 19 2009, 11:11 AM
Thanks how do I get to classic threads, I coudn't see it anywhere, Thank you, Joe
Lo-Fi Version | Time is now: 9th May 2024 - 03:02 PM |
