Fresh Air Fan, Troubleshooting |
elsargento |
Oct 19 2009, 06:53 PM
Newbie Group: Members Posts: 44 Joined: 9-September 06 From: Topanga, California Member No.: 6,802 |
Fresh air fan seems to be intermittent. Do I have to pull the gas tank to work on it?
Is there a thread on this topic I can go to? (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) |
neil30076 |
Oct 19 2009, 06:56 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
Fresh air fan seems to be intermittent. Do I have to pull the gas tank to work on it? Is there a thread on this topic I can go to? (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) Hard to get to main fan without pulling tank ! |
flipb |
Oct 19 2009, 07:25 PM
Senior Member Group: Members Posts: 1,722 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
As a newb, I think this is a rite of passage for me:
"Clean your grounds" I've only been a 914 owner for a couple months and some of my electrical components seem intermittent as well (radio). I suspect that it's an electrical issue - clean all the fuse contacts in your fuse panel and your grounds before you go so far as pulling the gas tank. |
markb |
Oct 19 2009, 10:59 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Take out your ashtray & point a flashlight slightly to the right & you'll see the contacts. You might start by cleaning them. (IMG:style_emoticons/default/smile.gif)
elsargento |
Oct 20 2009, 08:11 PM
Thanks for all the tips gentlemen. I actually took out the bolt and removed the lever controller and cleaned the contacts..there was 12 volts and clean contacts..still no fan guess I'll drive it till the tank is close to empty..pull it and check the connections at the fan..Maybe leave the swithch on and hit some good speed bumps and bounce the front maybe clean a bad ground...just kidding but guess the tank is next..thanks all
neil30076 |
Oct 20 2009, 08:21 PM
...just kidding but guess the tank is next..thanks all The main fan, under the fresh air vent in front of the windshield self destructs, the plastic frame holding the motor breaks up in the sun and heat, or varmints eat it, and it's not repairable. Down here in SD i can live without it, I just leave the targa top off! |
Lo-Fi Version | Time is now: 20th May 2024 - 12:57 PM |
