Thread On Relocating Fuel Pump? |
kenshapiro2002 |
Oct 20 2009, 07:57 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
DAMN! I want that (without doing the needed modification).
BTW...besides the sock, is it just one gasket I need after I remove the feed line? ??? late fuel pumps are physically in the same space as the gas tank and are accessible through the front trunk where a small panel is located on the vertical wall covering the access hole. |
Gint |
Oct 20 2009, 08:20 AM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
DAMN! I want that (without doing the needed modification). (IMG:style_emoticons/default/lol-2.gif) You could write a check... |
kenshapiro2002 |
Oct 20 2009, 08:23 AM
Think I'll just leave my pump in the original spot. (IMG:style_emoticons/default/happy11.gif)
VaccaRabite |
Oct 20 2009, 08:56 AM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
On a scale of 1 - 10, creating the access panel is about a 2, and only a 2 beacuase you have to use power tools.
Just find or buy the cover from someone here or AA or a scrapped 75-76 car, mark your cut, and take the 5 or so minutes that it will take to buzz it out with a sawzall or rotary cutter. Tank needs to be out, and you want to be sure you don't cut the feeder lines to the master cylinder from the brake fluid res, but it is a REALLY easy improvement. Zach |
kenshapiro2002 |
Oct 20 2009, 09:14 AM
OK...sell me yours.
On a scale of 1 - 10, creating the access panel is about a 2, and only a 2 beacuase you have to use power tools. Just find or buy the cover from someone here or AA or a scrapped 75-76 car, mark your cut, and take the 5 or so minutes that it will take to buzz it out with a sawzall or rotary cutter. Tank needs to be out, and you want to be sure you don't cut the feeder lines to the master cylinder from the brake fluid res, but it is a REALLY easy improvement. Zach |
kenshapiro2002 |
Oct 20 2009, 09:35 AM
Hey...if I use the current fuel pump to empty out my gas tank (as opposed to using a siphon) how long will it take to pump out 10 gallons?
SLITS |
Oct 20 2009, 09:42 AM
13 gallons per hour output .... Check you Haynes manual ....
It will also drain the tank, free discharge, if you disconnect the suction line to the pump. |
tod914 |
Oct 20 2009, 09:46 AM
Just pull the line after the filter no? No need to run the pump.
kenshapiro2002 |
Oct 20 2009, 10:10 AM
tod914 |
Oct 20 2009, 06:03 PM
Smart idea running it into another car. Certianly beats umteen cans of gas laying around.
kenshapiro2002 |
Oct 20 2009, 06:36 PM
Love you too man! (IMG:style_emoticons/default/aktion035.gif)
Smart idea running it into another car. Certianly beats umteen cans of gas laying around. |
kenshapiro2002 |
Oct 21 2009, 05:43 AM
Just what I did.I'll wait until the tank is out to cut, but do you have any measurements or guidelines as to where it should be? I'm guessing it'll be apparent once I get the tank out.
VaccaRabite |
Oct 21 2009, 06:42 AM
kenshapiro2002 |
Oct 21 2009, 07:00 AM
VaccaRabite |
Oct 21 2009, 07:18 AM
Crap. You found the only chink in my armor. Curse you and your black arrow, Bard of Esgaroth!
kenshapiro2002 |
Oct 21 2009, 07:25 AM
Love snails! (IMG:style_emoticons/default/stirthepot.gif)
Crap. You found the only chink in my armor. Curse you and your black arrow, Bard of Esgaroth! Sure...as long as it's not green! OK...sell me yours. 15K and you can drive it home tomorrow. I'd just have to build me a new one. Zach |
kenshapiro2002 |
Oct 27 2009, 02:00 PM
Two questions before I proceed:
#1. How (where?) did ya'll run the positive wire when taking it form the original location up to the front? Through the tunnel with the fuel line? #2. Just got the CB rotary pump and it's included filter. There's about 1" of hose between the pump and the filter. It seems it would be easier to remove the pump and filter if there were more distance between the two. Did you leave the filter that close to the pump or separate them more? |
neil30076 |
Oct 27 2009, 02:23 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
Two questions before I proceed: #1. How (where?) did ya'll run the positive wire when taking it form the original location up to the front? Through the tunnel with the fuel line? #2. Just got the CB rotary pump and it's included filter. There's about 1" of hose between the pump and the filter. It seems it would be easier to remove the pump and filter if there were more distance between the two. Did you leave the filter that close to the pump or separate them more? #1, pick up the wire off #15 on the ignition switch, run it through an in-line 15A fuse to the new position, much easier than trying to reroute the old wire. #2, I would not separate them, it fits just fine as it is. #3, prepare next thread re: how to install the SS fuel line (IMG:style_emoticons/default/lol-2.gif) |
kenshapiro2002 |
Oct 27 2009, 05:10 PM
I was kind hoping the enclosed directions were sufficient! (IMG:style_emoticons/default/WTF.gif)
kenshapiro2002 |
Oct 27 2009, 05:26 PM
The black one! Two questions before I proceed: #1. How (where?) did ya'll run the positive wire when taking it form the original location up to the front? Through the tunnel with the fuel line? #2. Just got the CB rotary pump and it's included filter. There's about 1" of hose between the pump and the filter. It seems it would be easier to remove the pump and filter if there were more distance between the two. Did you leave the filter that close to the pump or separate them more? #1, pick up the wire off #15 on the ignition switch, run it through an in-line 15A fuse to the new position, much easier than trying to reroute the old wire. #2, I would not separate them, it fits just fine as it is. #3, prepare next thread re: how to install the SS fuel line (IMG:style_emoticons/default/lol-2.gif) T |
Lo-Fi Version | Time is now: 28th May 2024 - 07:51 PM |
