914 turbo or twin torbo ?, motor building |
glenn87 |
Oct 20 2009, 04:58 AM
Newbie Group: Members Posts: 7 Joined: 19-October 09 From: va Member No.: 10,955 Region Association: None |
i have just bought a kit car with a 914 motor do not know any thing about it i will pick up 10/24 09 my question is can i put a turbo or because it has duel carbs a twin turbo set up ? and second what kind of horsepower/ tourque numbers can i get from this motor ? thanks for helping a newbie
Mark Henry |
Oct 20 2009, 05:09 AM
782bhp for 3.2 seconds (IMG:style_emoticons/default/blowup.gif)
Can't turbo a 914....(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/welcome.png) |
glenn87 |
Oct 20 2009, 05:59 AM
why not ? i dont know anything about thes motors. i know you can do a vw . i do have a lot of room behind motor as its a kit car
(IMG:http://i264.photobucket.com/albums/ii182/mole234/914motor.jpg) |
type47 |
Oct 20 2009, 07:09 AM
What you have is a little bit different than a TypeIV motor in a 914. We/they say "you can't turbo a 914" mostly as a tongue in cheek inside joke. With a 914, there is no easy fit of the turbo and all the associated plumbing and some sort of induction style (carbs? EFI?) due to the mid engine placement. In your pic, you have a "tail dragger"/rear engine so you are not looking to "turbo a 914", you're looking to turbo a TIV located as a rear engine and I think it will be fairly easy to do your situation due to engine location. Still, since it's not a TypeI, you will be going into some uncharted territory and may have a bit more fabrication than a typeI. Keep us informed about your project....
PS: where in VA are you? |
ottox914 |
Oct 20 2009, 07:38 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
See the links in my sig.
It CAN be done but not easily. Buy and read: Maximum boost, by corky bell. Do plenty of research and good luck! |
Mark Henry |
Oct 20 2009, 11:19 AM
Ya I was being a dick.....up at 4am does that to you.
Can be done, has been done, you have to fab and research every last detail. Not a huge knowledge base and support compared to the type 1. Type 4 there are many issues to overcome and it's not cheap. Type 1 is way easier to turbo and to me a better choice. Lot's of reading and searching to do. good luck! |
glenn87 |
Oct 20 2009, 03:43 PM
Ya I was being a dick.....up at 4am does that to you. Can be done, has been done, you have to fab and research every last detail. Not a huge knowledge base and support compared to the type 1. Type 4 there are many issues to overcome and it's not cheap. Type 1 is way easier to turbo and to me a better choice. Lot's of reading and searching to do. good luck! thanks all i also have kelmark chassie with olds 455 motor i may be able to use i'll see witch is cheaper |
Lo-Fi Version | Time is now: 11th May 2024 - 10:13 AM |
