Glass fuel filters- What are your thoughts?, Yea or Ney? |
URY914 |
Oct 23 2009, 02:23 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,758 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
These things have been around for a long time. VW guys have been using them forever. Advanages being you can see the junk thru the glass and you can clean and reuse them. They are cheap at about $8.00.
Down side is they are glass and can break. IIRC they are not SCCA legal for this reason. If you use them do you install them in the engine compartment where it is less likely to be hit by a rock and break. But when they do break they allow gas to cover the engine. Or do you mount them up under the engine shelf out of the way so when they break they dump gas on the road? Has anyone ever heard of one breaking? I have one for my street car and don't know if I should install it or get a typical OEM plastic/steel body one from my FLAPS. What say you??? Attached image(s) |
J P Stein |
Oct 24 2009, 08:49 AM
I've beed using one made by Russell (AN fittings) in conjunction with SS braided lines for 10-12 years. It's clear but I'm can't tell if it's glass or plastic tho I think it's the fromer. Mounted on the rear firewall. I clean it ever couple years. No leaks or breakage. I have no carb issues either. Ain't I lucky.
ME733 |
Oct 24 2009, 09:29 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
I've beed using one made by Russell (AN fittings) in conjunction with SS braided lines for 10-12 years. It's clear but I'm can't tell if it's glass or plastic tho I think it's the fromer. Mounted on the rear firewall. I clean it ever couple years. No leaks or breakage. I have no carb issues either. Ain't I lucky. YES |
kenshapiro2002 |
Oct 24 2009, 09:32 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Please show pictures...getting ready to do this next week. Converting my '70 to pump-up-front with an access panel off of a late model too.
Now I have a clean tank, new hoses, and new filter. It also didn't have a fuel pressure regulater so I added one. I'll finish the install tomorrow a.m. |
zymurgist |
Oct 24 2009, 09:44 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
And the hose between the tank and the fuel line in the tunnel? It was crap also. An accident waiting to happen... (IMG:style_emoticons/default/yikes.gif) |
aircooledtechguy |
Oct 24 2009, 11:27 AM
And the hose between the tank and the fuel line in the tunnel? It was crap also. An accident waiting to happen... I would also recommend ditching those clamps you were using and switch to either of these since these styles won't cut into the hose and cause leaks. . . |
kenshapiro2002 |
Oct 24 2009, 12:00 PM
Confused (not the first time)...how are his clamps different form the second one in your recommended example?
rfuerst911sc |
Oct 24 2009, 04:12 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I agree about the glass type...not good...Rick, where did you get the metal can type filters? Do you have any pics of what they look like? Hi Brian the front fuel filter came with the CB Performance rotary fuel pump but it's a standard looking fuel filter can. The one I installed in the engine compartment is a Purolator # 54618. It's a standard can but comes in/on a mounting plate. This size with the plate fit perfect next to my battery and bolted to a plate near the battery towards the rear. Not sure what OEM part normally bolted on there. |
Katmanken |
Oct 24 2009, 10:19 PM
I ran those things on my Karmann Ghia and my wife's bug for over 10 years with no problems.
Of course, the country of manufacture AND quality has probably changed by now...... |
Cevan |
Oct 24 2009, 10:25 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
ClayPerrine |
Oct 24 2009, 10:35 PM
Life's been good to me so far..... Group: Admin Posts: 15,476 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I use a small Ford carburetor fuel filter in front of the FI pump. This is on the suction side of the pump, so it never receives any high pressure. I found one that has the same size fitting as the large line on the tank, and the other side is a threaded pipe fitting. I hook a barb that has the same size fitting as the pump to it. That keeps the crap out of the pump. I did this because the sock in the tank had disintegrated, and when I checked they were NLA.
On the pressure side of the FI pump, before the injectors, I put in a filter from a Fuel Injected Nissan. It is quite capable of handling over 60 psi, and has the proper size fittings on both the inlet and the outlet to insert inline inside the engine compartment. I don't remember the part number on the Ford filter, but it is a common one. I pull the old one and go buy a new one. The inline filter was the same one used on my 87 Nissan Pulsar. |
kenshapiro2002 |
Oct 24 2009, 10:54 PM
That would make sense, but he said "I would also recommend ditching those clamps you were using and switch to either of these since these styles won't cut into the hose and cause leaks. . ."
Confused (not the first time)...how are his clamps different form the second one in your recommended example? I think he means use the first one (FI style clamp) and not the second one, which will cut into the hose. |
kenshapiro2002 |
Oct 24 2009, 10:56 PM
The fuel tanks socks are definitely available...got one today from AA.
I use a small Ford carburetor fuel filter in front of the FI pump. This is on the suction side of the pump, so it never receives any high pressure. I found one that has the same size fitting as the large line on the tank, and the other side is a threaded pipe fitting. I hook a barb that has the same size fitting as the pump to it. That keeps the crap out of the pump. I did this because the sock in the tank had disintegrated, and when I checked they were NLA. On the pressure side of the FI pump, before the injectors, I put in a filter from a Fuel Injected Nissan. It is quite capable of handling over 60 psi, and has the proper size fittings on both the inlet and the outlet to insert inline inside the engine compartment. I don't remember the part number on the Ford filter, but it is a common one. I pull the old one and go buy a new one. The inline filter was the same one used on my 87 Nissan Pulsar. |
type47 |
Oct 25 2009, 07:37 AM
I am hoping that the 2 clamps shown are OK to use as a VW mechanic installed the second one on an engine of mine. I think the clamp to avoid is the common hose clamp that you buy at Home Depot/Lowes/Ace where there are slots in the band which can cut the hose and therefore cause leaks, although, on second thought, one of the clamps pictured would seem to do the same. Factory FI clamps even have a slight upturned edge
URY914 |
Oct 25 2009, 08:13 PM
I have changed all the rubber hoses, the fuel filter, and added a pressure regulator. Today I completed it all. Drove it and it still backfires thru the left side carb when I'm running steady in 3rd gear at 2500 rpm . Tried adjusting the idle screw all the way in and out on both throats and it nearly died so jets are not clogged.
I need to check to see if they are syn'd properly. |
type2man |
Oct 25 2009, 08:20 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
You might have an intake leak. Does it idle smooth after about 20 seconds of being at idle. Mine didn't idle smooth, it used to stumble, turns out I had an intake leak on one of the intakes that caused a popping while crusing on the expressway.
URY914 |
Oct 25 2009, 08:48 PM
I'll check again but I've snuged things down pretty tight.
carr914 |
Oct 25 2009, 09:23 PM
Racer from Birth Group: Members Posts: 118,774 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I've always run a BMW metal cannister filter that's the size of a Fosters beer can. I mount a bicycle water bottle cage to hold it.
T.C. Paul, I thought your car sounded a little rough leaving the other day. |
JazonJJordan |
Oct 25 2009, 11:37 PM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
My 66 Chevy Pickup had one (still does today-) for 30 years and no problems but the concern is justified.
In the engine compartment hanging over a 160+degree engine and too many parts to spark like the HiAmp starter a foot away, does not seems wise. Even if I have had no issues ...yet. A pool of gas under the car -anywhere- could be a disastrous end to you and yours. For those old gas water heater garages- it really could be. Even just a crack. I like them myself and they function. But they function at too much a risk for me on this car but would gladly have a clear plastic version. Relocated of course. Good luck- |
campbellcj |
Oct 26 2009, 12:53 AM
I have a large metal Canton filter up front and a metal inline filter (forgot the brand) in the engine compartment near the regulator and pressure gauge - both AN-6 screw-on types. The glass scares the crap out of me and plastic almost as much, knowing how a lot of people tend to neglect inspecting/replacing such things on their cars. Present company excepted, of course. (IMG:style_emoticons/default/wink.gif)
ME733 |
Oct 26 2009, 11:11 AM
I have changed all the rubber hoses, the fuel filter, and added a pressure regulator. Today I completed it all. Drove it and it still backfires thru the left side carb when I'm running steady in 3rd gear at 2500 rpm . Tried adjusting the idle screw all the way in and out on both throats and it nearly died so jets are not clogged. I need to check to see if they are syn'd properly. (IMG:style_emoticons/default/popcorn[1].gif) ..(.assumption the carburators are perfectly adjusted , inc. all linkages) float levels and float needle are perfect and not "hanging up"(or down) . THEN, well maybe....remove carbs and dump out the accumulated WATER., drain, fuel in tank check for WATER.. install NEW fuel filters .AND/ OR...valves need adjusting , broken valve spring, bent valve(s). head needs valve job.etc..Look for the reason the intake charge is reversing during the firing cycle.("BLOWING BACK"). Too early ignition timing can also be a problem.worn or bouncing points.loose wiring , breaker plate or points, in distributor...misreading the T.D.C.... (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:44 PM |
