It's official, fuch the /4...... I'm doing a six, I'm nuts, JP wins |
Mark Henry |
Oct 26 2009, 09:56 AM
So.... I got all these cool parts, straight trade, his junk for my junk.
Doesn't matter how I look at this, a big four adds almost 0 value to a 914, stick a six in and it's worth a lot more. Especially here in Canada! I'm actually down sizing from a 2.7 T4 to a 2.0 six (IMG:style_emoticons/default/screwy.gif) I got a 75 911S with 69T 2.0 engine and trans, plus four fuchs. I could break this and make a nice tidy profit, but I don't like to tempt fate. I think it would be bad karma to pass this up. I only have 2 of the four fuchs right now but I'm asured I'll have the other 2 and an extra seized 911 engine. No info other than it's seized. The engine has a lot of cool stuff on it 40IDA webers, a 69S dizzy, permatune and turbo lower covers. The guy also said it has "hot cams" so my fingers are crossed and maybe there's some more goodies in there. It turns over nice, lots of meat on my 215mm flywheel (nice) and the cam lobes look good. I'll be doing a rootworks special and will make most of my own parts. I was hoping to use the '75 5-bolt rear hubs, but I think it's the wrong year. I'll get a set of rears hubs off of Eric. I have everything for a 2.7 nickies T4, I'm glad I haven't put it together because it now going in my bug. Almost like fate man, far out. I have no money, but I have a whack (I had a whole other stroker engine for the bug) of nice T4 stuff that will be in the classifieds real soon. I'll be listing some stuff today (and later this week) here first before the samba! I'll trade for /6 parts (IMG:style_emoticons/default/biggrin.gif) -- Cheers Mark Attached image(s) |
Mark Henry |
Oct 26 2009, 10:07 AM
The boss telling me how to do it right!
He's a working boss though.....My 8 year old stripped out almost the whole 911 interior! Worked beside me all day. (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
sww914 |
Oct 26 2009, 10:12 AM
A 6 is a good engine. They routinely go 200K, big 4's don't do that very often.
Mark Henry |
Oct 26 2009, 10:13 AM
Is the holes on the flywheel normal?
I know how the engine works and I'll do the work myself, but I will ask stupid questions. Attached thumbnail(s) |
Mark Henry |
Oct 26 2009, 10:18 AM
Transmission is a 4 speed, it will be mated to a 914 5 speed and I'm putting this in my bug.
GeorgeRud |
Oct 26 2009, 10:21 AM
The holes are normal, it sounds like you have a nice project ahead of you.
I also agree that the -6 should be a lot more fun than the -4, and will last longer. A 2.0 liter S engine is quite peaky, but should give you a good time. It will bolt right up to the 914 transmission with that flywheel. You will need headers, an engine mount, and will have to modify the oil cooler outlet. An oil tank and the necessary lines will also add to the cost. Good luck with the project. |
Lavanaut |
Oct 26 2009, 01:06 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Sounds cool Mark, and it's awesome to see your son out there helping you out!
As the owner/driver of that same engine (essentially), I have to ask if you've ever driven one. Because for a short time I had a stock 2.0-4 and my six. Around town I actually felt the 4 was more fun to drive. My point is, doing a six conversion but only going to a 2.0 seems like an awful lot of time and money spent for a modest performance gain, and then really only at the top of the RPM range. You've been around here a lot longer than I have, and I'd wager you've been around 914s FAR longer than I have, so don't take this all the wrong way if what I'm telling you is old news. But I did think it was worth mentioning, just in case you've never piloted a '69 2.0-6. (IMG:style_emoticons/default/smile.gif) I'll pass along an idea that came to me by way of the same Eric you mention - doing some reversible mods to end up with a 2.2S might be a good option if you're going to be in there anyway. Whatever direction you go, keep up the pics! Reid |
messix |
Oct 26 2009, 01:33 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
if you can get that back glass outta there with out breaking it you'll get a good chuck of change for it i imagine!
and if your gonna do a rootwerx specail your gonna need to get set 2.7p/c and make it a screaming 2.5! |
carr914 |
Oct 26 2009, 02:12 PM
Racer from Birth Group: Members Posts: 118,498 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Mark Henry |
Oct 26 2009, 02:16 PM
if you can get that back glass outta there with out breaking it you'll get a good chuck of change for it i imagine! and if your gonna do a rootwerx specail your gonna need to get set 2.7p/c and make it a screaming 2.5! I mean I'm going to try to do this cheap (IMG:style_emoticons/default/biggrin.gif) I have the fab and rebuild skills. I can do the valve job myself etc. engine, tin mount I'll make. Been awhile but I've built a couple /6's before. As for the engine, yes it's small oh well, too big will just get me in trouble. Up here we don't have much cheap 911 parts and several businesses scourer the want ads and scoop all the deals. I know that dizzy is worth $600. They would break this deal up and ask a fortune for every little bit. I didn't think the glass would be worth much? Just lay on your back and kick it out, but you have to have someone to catch BTDT (IMG:style_emoticons/default/smile.gif) |
SLITS |
Oct 26 2009, 02:24 PM
Just throw money.
A '69T motor is 110 HP @ 5800 RPM. A true '69S engine is 170 HP @ 6800 RPM. |
Ian Stott |
Oct 26 2009, 02:35 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Get er done! Then set your sights on Moncton, we can go for lobster and beer! Missed out on you visiting me last time you were down this way, can't let it happen again, you know I am alone here in muscle car country! Starting to organize a Porsche/Moncton group to go to the former "British cars only" car show in PEI which has opened up to anyone, and it is not a muscle car show. Moncton hosts Canada's largest car show and it is great but I like the smaller show in PEI as it is sports cars, plus the ride over is hard to beat. Interested??
Ian Stott Moncton Canada PS: I am sure you are going to have a real nice car when you are done and I look forward to seeing it. |
MDG |
Oct 26 2009, 02:49 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
It'll be a blast! I have one of each and love them both; the 2.2 motor will be replaced this winter with a 3.2 (IMG:style_emoticons/default/smile.gif) Let me know if you need any parts; I have an almost new pair of Marty Schneider's (MSDS) headers on mine but they'll be too small on the 3.2; not sure what I'll do with the Webers either - I'm leaning towards keeping the FI on the 3.2
Upgrade the tensioners while you're at it. |
Ferg |
Oct 26 2009, 02:55 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
How is the dash and other interior bits from the 911, I may be interested.
Ferg |
Mark Henry |
Oct 26 2009, 06:30 PM
How is the dash and other interior bits from the 911, I may be interested. Ferg Dash is cracked, the car is pretty beat up, no front, doors, visors and the interior is real dirty, I have all the little bits and most of the dash switches, but I'm keeping the gauges. PM me your wants and make a fair offer. I'm not marrying this engine (IMG:style_emoticons/default/sheeplove.gif) it's a stepping stone like the 2.2 in MDG's car. It's worth a few bucks more (at trade time) if it's a running engine up here. It could be junk, I'm looking to fix the tensioner maybe a top end job and rings. Anymore and I'll reevaluate the situation. I'm not jumping like a mad man, I have 6 months. Lot's of time to find more deals and make fair trades. I don't have time to tear into the engine till next month. My teen is a narrow body street car, the odd AX and maybe some day a 3.0. I was thinking just M calipers (which I have) and Erics V caliper kits. Now the '75 rear brakes I have, are they any good to me? I have the fab skills These look pretty clean and I know 911 guys are looking to this upgrade because of the AL arms. Bunch of this 911 stuff I have no clue on the value and will have to do some research. (IMG:style_emoticons/default/rolleyes.gif) |
J P Stein |
Oct 26 2009, 08:54 PM
I don't win, you do. (IMG:style_emoticons/default/biggrin.gif)
pete-stevers |
Oct 26 2009, 09:08 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
Dr Evil |
Oct 26 2009, 09:43 PM
Mark, I have some special tools you can use when you start goofing with the cams (IMG:style_emoticons/default/smile.gif)
Mark Henry |
Oct 26 2009, 09:54 PM
Mark, I have some special tools you can use when you start goofing with the cams (IMG:style_emoticons/default/smile.gif) Thanks Doc I sold the correct factory cam bolt wrench last year (IMG:style_emoticons/default/headbang.gif) I barely remember the first 2.4 I did, been a long time. I made the locator pin tool out of an old nail (IMG:style_emoticons/default/lol-2.gif) |
ClayPerrine |
Oct 26 2009, 10:36 PM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Mark, I have some special tools you can use when you start goofing with the cams (IMG:style_emoticons/default/smile.gif) Thanks Doc I sold the correct factory cam bolt wrench last year (IMG:style_emoticons/default/headbang.gif) I barely remember the first 2.4 I did, been a long time. I made the locator pin tool out of an old nail (IMG:style_emoticons/default/lol-2.gif) Spark plug fits perfectly.... (IMG:style_emoticons/default/biggrin.gif) I bought a pair of digital indicators from Harbor (OOPS.. sorry you are in Canada so Harbour) Freight. That way I didn't have to switch them from side to side. They were 39.00 US each. I don't own the cam wrenches, but I can borrow them anytime I need them..... (IMG:style_emoticons/default/biggrin.gif) The only problem with a six is that once you have one, you want a bigger one!! |
Lo-Fi Version | Time is now: 10th May 2024 - 06:18 AM |
