More L-jet questions, edit : Engine is Finished |
jsayre914 |
Oct 31 2009, 10:34 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
so, what i thought was a cake walk is proving to be more of a pita. i pulled up jeffs l-jet diagram to check my connections and i could not believe it.
i labled all wires when i pulled the injection off. jeffs diagram tells me the fuel injector leads on both sides are backwards??? (IMG:style_emoticons/default/WTF.gif) the engine was running fine when i pulled it, but his diagram describes the left side and right side with (short/ long) and mine are definatly opposite on both sides (IMG:style_emoticons/default/blink.gif) how can that be. the delema..... should i hook it up the same way i took it off or do i do it as per the guru of 914 fi??? and now i am having a bitch of a time getting the vacume leads to make sense. there is at least 5 diff diameters and i have diagrams from aa pelican and jeffs website. they all say slightly diff things. i bought the vacume kit from aa and it seems to not fit some of the fittings it is supposed to fit. (IMG:style_emoticons/default/headbang.gif) i am still having fun anybody want to help put my engine back in the car (IMG:style_emoticons/default/bye1.gif) |
davesprinkle |
Oct 31 2009, 05:29 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
so, what i thought was a cake walk is proving to be more of a pita. i pulled up jeffs l-jet diagram to check my connections and i could not believe it. i labled all wires when i pulled the injection off. jeffs diagram tells me the fuel injector leads on both sides are backwards??? (IMG:style_emoticons/default/WTF.gif) the engine was running fine when i pulled it, but his diagram describes the left side and right side with (short/ long) and mine are definatly opposite on both sides (IMG:style_emoticons/default/blink.gif) how can that be. the delema..... should i hook it up the same way i took it off or do i do it as per the guru of 914 fi??? and now i am having a bitch of a time getting the vacume leads to make sense. there is at least 5 diff diameters and i have diagrams from aa pelican and jeffs website. they all say slightly diff things. i bought the vacume kit from aa and it seems to not fit some of the fittings it is supposed to fit. (IMG:style_emoticons/default/headbang.gif) i am still having fun anybody want to help put my engine back in the car (IMG:style_emoticons/default/bye1.gif) Yeah, the vacuum line thing can be irritating. Just persevere and it'll work out. Regarding the fuel injectors -- it doesn't really matter how you hook them up. They all fire simultaneously anyway. |
zonedoubt |
Oct 31 2009, 06:33 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Disconnect the connector (J21) at the ECU.
Disconnect all the fuel injector connectors (N19, N20). Use an ohmmeter to trace the fuel injector terminals back to the ECU connector terminals, using the pinouts as shown in the circuit diagram. |
jsayre914 |
Nov 1 2009, 11:33 AM
ENGINE IS DONE !!!
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/beer3.gif) now i need to put it back in the car. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) for anybody that does not know my engine saga... i purchased an extra 1.8 engine w/ fi that was running as a temporary engine, plug and play so that i could rebuild my 2.0 d-jet into a raby 2056. everything went fine with the swap, then i found out when we removed the exhaust the stud on one of the cylenders was held in with some jb weld, hence the exchanger would not bolt back on. (IMG:style_emoticons/default/headbang.gif) so mike came over and helped me drop the 1.8 back out so i could have somebody weld a billet plug into the head and tap a new stud. that went fine untill we noticed a huge crater in the side of piston 2. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) so we pulled the other head and i went ahead and purchased a piston/ cylender set cheap enough from performace. I got my first partial rebuil expierence under my belt. when i put it all back togeather with mikes help i went ahead and painted the tin, replaced all vacume and fuel hoses, plugs, wires, seals, anything i could make like new. and now, i am right where i started with my temporary engine so i can build my engine (IMG:style_emoticons/default/huh.gif) |
jsayre914 |
Nov 1 2009, 05:40 PM
anybody opposed to me putting the motor back in by myself??
(IMG:style_emoticons/default/confused24.gif) i figure it is a two person job, but after searching i found lots of people have done it. i weigh about 140lbs and it weighs about what 350lbs no problem right. im just too excited to get it back in there and fire it up. (IMG:style_emoticons/default/popcorn[1].gif) |
zx-niner |
Nov 1 2009, 07:38 PM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
anybody opposed to me putting the motor back in by myself?? (IMG:style_emoticons/default/confused24.gif) i figure it is a two person job, but after searching i found lots of people have done it. i weigh about 140lbs and it weighs about what 350lbs no problem right. im just too excited to get it back in there and fire it up. (IMG:style_emoticons/default/popcorn[1].gif) Balance the engine/tranny on a floor jack. Let the floor jack do the lifting work, take your time lining things up, and make sure nothing hangs over the edges of the engine tin as you lift the engine into the bay. That's how I have always done it. Slow and easy, stop and look around all edges frequently as it goes up. Lose fit nuts and bolts to each corner as you get them lined up. The most difficult part ends up being raising the car high enough to get the engine under it and around the axles to start the lift. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:18 PM |
