| burton73 |
Oct 31 2009, 06:29 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,041 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
My driver’s door has this problem where you can lock it or turn it with the key to the right fine but it does not want to come back to the left clean all the time. The keys work in all the locks and are in good shape. I have tried two different sets the red one and the black. A new set and an original set from the car.
I was on the phone with Eric Shea for something different and he thought because it was sticking to spray brake cleaner in the key slot. I did put the red nosel in deep and gave the lock a lot of cleaning. I know I did a good job as there was a bit of black grease that came out. I did this 3 times. It stills will not work like the right door. I have to turn it to the right then left a few times to get it to unlock. It seems to lock fine but does not want to unlock at this tumbler. Do you think if I take an extra tumbler from a different lock to a locksmith to match to my key this will work as my pins may be warn or the lock may be screwed. Any ideas. Bob (IMG:style_emoticons/default/headbang.gif) |
| Pat Garvey |
Oct 31 2009, 07:17 PM
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
My driver’s door has this problem where you can lock it or turn it with the key to the right fine but it does not want to come back to the left clean all the time. The keys work in all the locks and are in good shape. I have tried two different sets the red one and the black. A new set and an original set from the car. I was on the phone with Eric Shea for something different and he thought because it was sticking to spray brake cleaner in the key slot. I did put the red nosel in deep and gave the lock a lot of cleaning. I know I did a good job as there was a bit of black grease that came out. I did this 3 times. It stills will not work like the right door. I have to turn it to the right then left a few times to get it to unlock. It seems to lock fine but does not want to unlock at this tumbler. Do you think if I take an extra tumbler from a different lock to a locksmith to match to my key this will work as my pins may be warn or the lock may be screwed. Any ideas. Bob (IMG:style_emoticons/default/headbang.gif) Bob, Now that you have cleaned out all the accumulated crud, why not spray some lube in there? WD-40 is a start, but you may need heavier lube. Sounds likeyou have dry tumblers. Pat |
| Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
| markb |
Oct 31 2009, 07:27 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
You may also need to clean the actual door mechanisms. They get gummed up & won't let the actuator move freely.
| kenshapiro2002 |
Oct 31 2009, 07:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Just did mine...took the lock cylinder all the way out and even removed the tumblers and springs (keep them in order)...hand cleaned each one and the cylinder itself. Removed the door handle and cleaned every part. Works like any 2010 car out there. Before, I thought I had the been given the wrong key by the PO (wouldn't turn at all), and had to shoulder the door from inside to get out.
BTW...I wouldn't spray brake cleaner anywhere near my paint. |
| Jerry75914 |
Oct 31 2009, 08:08 PM
Member ![]() ![]() Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
I had the same problem. As several folks have already said, clean, clean, clean...that's step one.
When you have it apart, as in the photo above where the piece with the actuator arm is off (the one circled in red), you'll notice there is a square machined out of the inside, and on the end of the tumbler is a corresponding square that sticks out and fits neatly inside it. On my lock, part of the square on the end of the tumbler had broken off, so it had some grip to turn right, but not enough to move the actuator left. I ended up removing what was left on the end of the tumblre, fabricating a small metal sware to take it's place, and supergluing the whole mess together with a new screw and pressure washer. It has worked great ever since...but I do unlock the door gingerly! (IMG:style_emoticons/default/biggrin.gif) |
| burton73 |
Oct 31 2009, 08:59 PM
I just had the right handle off today, as the plastic was broken so the door would not open from the outside and I put the new repair kit on. I take it that the Philips screw that I removed is what is holding on the lock mechanism with spring that is circled in red.
I guess the tumbler comes right out. I will clean the shit out of in my solvent sink. The mechanism must be what is held on with the large Phillip’s head screws when you open the door. Solvents clean this as well and then what to use as lube? Bob |
| orange914 |
Nov 1 2009, 04:18 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i'm not clear if you can turn the key both ways. if you can turn both ways and it locks but does not unlock then:
I had the same problem. On my lock, part of the square on the end of the tumbler had broken off, so it had some grip to turn right, but not enough to move the actuator left. i had this problem too. i converted to the "square" on the end type. my early 73' had 2 pins instead (1 had sheared off). i assume the pin type end is early and suare is late. make sure the screw in the end of the tumbler is tight. p.s. make sure the key return spring is installed in the notches right when you put the end peice back on |
| burton73 |
Nov 2 2009, 12:55 PM
i'm not clear if you can turn the key both ways. if you can turn both ways and it locks but does not unlock then: I had the same problem. On my lock, part of the square on the end of the tumbler had broken off, so it had some grip to turn right, but not enough to move the actuator left. i had this problem too. i converted to the "square" on the end type. my early 73' had 2 pins instead (1 had sheared off). i assume the pin type end is early and suare is late. make sure the screw in the end of the tumbler is tight. p.s. make sure the key return spring is installed in the notches right when you put the end peice back on It gets hung up on the counter clock wise turn and you need to keep turning it to the right then left till it hits this spot where it needs to get past. It takes screwing around with. Not Porsche like. Bob |
| underthetire |
Nov 2 2009, 12:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I was told to use powdered graphite as a lube, not oil. I dunno what is correct though.
| kenshapiro2002 |
Nov 2 2009, 01:41 PM
NO GRAPHITE! (IMG:style_emoticons/default/blink.gif)
I was told to use powdered graphite as a lube, not oil. I dunno what is correct though. |
| underthetire |
Nov 2 2009, 01:57 PM
Geez, you don't need to scream. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/laugh.gif)
| jetboy |
Dec 22 2009, 04:59 AM
914 Uber Noob ![]() ![]() Group: Members Posts: 205 Joined: 16-September 05 From: Riverside, CA Member No.: 4,810 Region Association: Southern California |
NO GRAPHITE! (IMG:style_emoticons/default/blink.gif) I was told to use powdered graphite as a lube, not oil. I dunno what is correct though. Sorry to revive, but, I am still wondering whats best for relubing after the degunking? |
| DBCooper |
Dec 22 2009, 05:52 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
NO GRAPHITE! (IMG:style_emoticons/default/blink.gif) I was told to use powdered graphite as a lube, not oil. I dunno what is correct though. Why not? I was taught to never use anything but graphite or a drying molybdenum spray in any tumbler lock. Any lubricant that's wet will attract and hold dust and grime, gumming up the mechanism so it won't work any more. Graphite won't go stiff in sub-freezing temperatures the way wet lubricant will, either. So why not graphite? |
| campbellcj |
Dec 22 2009, 03:29 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,714 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
AFAIK graphite is the lube of choice and has always worked for me. Moderate careful application is the key (no pun intended)
| koozy |
Dec 22 2009, 03:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 654 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
works well for me too.
| Rob-O 1167 |
Dec 22 2009, 04:36 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 19-April 09 From: Mansfield, TX Member No.: 10,280 Region Association: None |
I've always used white lithium grease. They work smooth as silk afterwards. You're not trying to grease the part where the key goes in, but rather the outside of the cylinder and the inside of the housing.
| jonferns |
Dec 22 2009, 05:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
Wurth makes a great lube that sprays a similar consistency to WD-40 but then becomes thicker so it doesn't run, almost like a gel.
| kconway |
Dec 22 2009, 07:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I've always been told you never use an oil in lock cylinders as it will attract dirt and gum things up. Dry Graphite is the prefered lubricant for lock cylinders.
| Cap'n Krusty |
Dec 22 2009, 07:30 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I know a locksmith who is related to the guy who imports the Berner key machines, the ones made to do key work for German cars. He uses nothing but Tri-Flow, and agrees with the other locksmiths I know who warn that graphite accelerates wear in this kind of setup. As Tri-Flow is something we use around the shop, I see no reason to argue with an expert. BTW, WD 40 is a water displacer, not a lubricant.
The Cap'n |
Lo-Fi Version | Time is now: 1st July 2026 - 12:07 AM |
