5 lug wedge bolt headache |
barada |
Nov 1 2009, 02:10 PM
Member Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None |
Literally.
I have a redrilled front end right now as my 5 lug set up. One day driving home I saw a 84 carrera convertable on the side of the road. Asked how much for the entire front end they say 350, I tell them its a deal and I will be back sat. Well they call me and the "real owner" said he had to get 700 for it. I wound up getting just the struts and brake assembly. Now to the real question. I had a terrible time getting the wedge bolt out of the original struts from the 914. I thought re installing would be a breeze, well it has not even been close. 3 hours yesterday beating on the bolt it is probably 75% in, still sticking out about 1/4 of an inch from being flush. I have heated it a couple of times but there must be a trick to driving them in in a shorter amount of time. Car is a 74 914. Any hints or do I keep wailing away with the 4lb hammer and drift? Thanks Phillip |
JFJ914 |
Nov 1 2009, 03:02 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
STOP HAMMERING! The wedge pins can be distorted by too much hammering when removing, and most certainly are junk by now after all that hammering. Get some new ones and make sure they fit into the strut without beating on them. If not, determine what is not fitting. Also, make sure you you have "wedge" ball joints and not the half round "bolt" joints.
barada |
Nov 1 2009, 03:08 PM
STOP HAMMERING! The wedge pins can be distorted by too much hammering when removing, and most certainly are junk by now after all that hammering. Get some new ones and make sure they fit into the strut without beating on them. If not, determine what is not fitting. Also, make sure you you have "wedge" ball joints and not the half round "bolt" joints. Removing them is not the issue going in is. With the strut off, the bolts seem like they are the exact size of the opening. Ball joints are the wedge type. Like I said they have went in far enough to get the nut on with probably 2.5 threads showing, but I can still feel a tiny bit of play so I assume they need to go in further. I would have ground the opening out a little but this part IMO is one of the most important parts when it come to fitting correctly as I don't want o have the front end drop while driving. They are new by the way. |
JFJ914 |
Nov 2 2009, 10:37 AM
All I mean is if you've hammered on them as much as you've indicated, they could be "mushroomed" and will never fit. Did you line up the mark on the wedge with the "v" in the ball joint? Have you made sure the parts are rust free and clean? Are there any burrs that need smoothing? have you put some grease on the ball joint and pin so they can align? They do need to be tapped together, but they do not need to be "hammered". Where in Atlanta are you? PM me with your phone number and maybe I can talk you through it.
SLITS |
Nov 2 2009, 12:15 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
It's called a "double taper pin" and if not lined up with the wedge cut in the ball joint it won't go in.
barada |
Nov 2 2009, 08:22 PM
Thanks guys, it is positioned correctly, but I am thinking the hole in the strut may have been a little dirty and I don't think I used enough lube to get it in. I am probably going to have to put the old strut back in anyway if I want to drive it as one of the calipers is acting frozen so a rebuild is in need. Money pit this project has been.
pcar9146guy |
Nov 2 2009, 08:50 PM
Newbie Group: Members Posts: 32 Joined: 11-October 09 From: usa Member No.: 10,921 Region Association: None |
"Money pit this project has been."
Got jackstands???? Welcome to 914 land...... |
barada |
Nov 2 2009, 09:11 PM
barada |
Nov 5 2009, 07:27 PM
Well Problem solved. This is the most bizzare dealing I have had in my 20 years with cars. The car was a 84 model convertible, vin showed it was #250 ,BUT it had struts from a pre 73 car. The strut requires the bolt not the wedge pin. The duh moment came when I got out the SC calipers and checked them and they have 3 inch spacing not 3.5. Oh well back on with the redrilled set up until I can land some different struts.
SLITS |
Nov 5 2009, 09:47 PM
Get a set of "M" calipers ... 3" spacing and new ball joints for the early cars.
Lo-Fi Version | Time is now: 20th May 2024 - 11:08 AM |
