Cutting off Heat Shields to make straight - lite - headers..., Anyone ever done this? Worth doing? |
Cire |
Nov 3 2009, 08:28 AM
Member Group: Members Posts: 279 Joined: 12-March 09 From: Tucson, Arizona Member No.: 10,155 Region Association: None |
I have removed all my heater/fresh air stuff from the car. The exhaust still has those heat shields around them. I would love to get a header but they are a little out of my price range. Do I cut these and make them work or do I trade them to someone that has already done this? Just trying to figure out the best way to go on these. = )
Thanks. Eric |
michaelmoo |
Nov 3 2009, 08:32 AM
Member Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
I wouldn't do it. It wont make them true headers. They may look like them, but they are not equal length. Just use what you have and save for the headers.
tat2dphreak |
Nov 3 2009, 09:01 AM
you would gain nothing. an experienced muffler shop might be able to fab you a header, but it still wouldn't be cheap, or probably as well done as the tangerine.
if you want a stop-gap improvement, SSI H/Es have a larger diameter than stock. |
URY914 |
Nov 3 2009, 09:46 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,544 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Those look pretty good, maybe some one here will want to trade a set of rusted out ones for you good ones. Don't cut them up.
In the end there will be no advantage. That oil leak will drip on the exhaust and cause more smoke than it does now. |
ME733 |
Nov 3 2009, 10:59 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ....Your "heater boxes " do not look rusted out. Some one may need a set, and if sandblasted, would be paintable with high temp paint and even more useable., You can probably find some one to trade you/for Just the exhaust pipes/header pipes if thats what you want.....what engine /displacement are they from? info would help., and with just the hedder pipes, a good muffler shop or fabricator could (purchase)make a collector, and, "extractor""stinger", with a detachable muffler etc.(all the parts are available If you hunt around)....I clearly understand that the cost of any of the existing "racing exhaust systems" is expensive. I will be making my own also. (IMG:style_emoticons/default/popcorn[1].gif)
tat2dphreak |
Nov 3 2009, 11:08 AM
they are 1.7/1.8... the bend at the end...
QUOTE what engine /displacement are they from? info would help. |
Cire |
Nov 3 2009, 01:55 PM
they are 1.7/1.8... the bend at the end... QUOTE what engine /displacement are they from? info would help. Great information. = ) I wont hack them up. If anyone in AZ needs a good set let me know. Now... Anyone got a crap set I can play with? =- ) Thanks everyone for the info. Eric |
Lo-Fi Version | Time is now: 13th May 2024 - 04:39 AM |
