Conversion MPG ? |
Conversion MPG ? |
HUBBSTER |
Nov 3 2009, 10:17 AM
Newbie Group: Members Posts: 26 Joined: 31-October 09 From: Miami, FL Member No.: 10,996 Region Association: South East States |
I'm thinking of dropping an LS1 or LS3 into a 914
A stock C6 Vette w an LS3 cruises at 85 in 6th at 30 MPG I would imagine that w the same injection and computer the LS3 in a 914 would return considerably better MPG Have any of you LS1 or Scooby conversion guys checked your MPG ? Thanks |
messix |
Nov 3 2009, 10:23 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
the stock 914 tranny won't return the same mpg. the engine will be spinning to fast, the covette is only turning about 1500rpm or less to get that mpg.
you'd have to do a tranny swap or get real creative with the gears to come up with the final drive to get that high of gear. |
HUBBSTER |
Nov 3 2009, 10:30 AM
the stock 914 tranny won't return the same mpg. the engine will be spinning to fast, the covette is only turning about 1500rpm or less to get that mpg. you'd have to do a tranny swap or get real creative with the gears to come up with the final drive to get that high of gear. Thanks, so it seems a high overdrive 5th would help a lot |
underthetire |
Nov 3 2009, 10:39 AM
I agree with the tranny gear ratio. Way too high of RPM at fwy speed to get MPG.
toon1 |
Nov 3 2009, 03:51 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
you could flip third and put it in the 5th posistion. that would give you a tall fifth.
RJMII |
Nov 3 2009, 04:48 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
go with a Boxster S 6 spd and the LS_ engine. =o) Then you'll have sixth, and water cooled gear ratios, and that high MPG when you keep your foot out of it.
http://www.kennedyeng.com/vw_por.htm IIRC the 996 is the same as the Boxster S trans. A Cayman engine will bolt to a Boxster S transaxle. |
HUBBSTER |
Nov 3 2009, 04:53 PM
TonyAKAVW |
Nov 3 2009, 08:03 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
If I cruise at 60 with the roof off on the highway I can get 34 mpg in my suby conversion. That is wit a 2.5 liter naturally aspirated motor.
I suspect I could do better if I fixed a few little things with the motor. -Tony |
RJMII |
Nov 3 2009, 09:46 PM
go with a Boxster S 6 spd and the LS_ engine. =o) Then you'll have sixth, and water cooled gear ratios, and that high MPG when you keep your foot out of it. Sounds good. Do the LS1 and LS3 engines fit pretty much the same ? I have no idea. I've been trying to get an adaptor to run my Mitsubishi turbo V-6 with a Boxster S transmission. I've about got the plumbing figured out to go twin turbo and make it to where I can keep my rear trunk as a trunk. There's a lot of info out there about the 3000GT VR4 upgrades and HP numbers, only the 914 is a third of the weight. |
marks914 |
Nov 4 2009, 05:49 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I have been getting a pretty constant 21 with my SBC 302 with taller gears. Not apples to apples, but its a number
Even if you git the gearing down, the areo on the vette is way better than the 914 which will dramatically affect MPG. Mark |
HUBBSTER |
Nov 4 2009, 08:45 AM
charliew |
Nov 4 2009, 11:01 PM
THe corvette is slicker but it also weighs 3200-3400lbs. The 1500-1800 cruise rpms helps a lot but the emu is the real trick part.
Lo-Fi Version | Time is now: 13th May 2024 - 08:14 AM |
