Jet-Hot coated engine fan case??? /4 |
Mueller |
Mar 16 2004, 08:43 PM
I'm sending my header out to get coated, I had thought about getting the fan housing done at the same time....it would be the semi-bright silver finish...any reason not to????
Aaron Cox |
Mar 16 2004, 08:44 PM
why not the cylinders and the case? ( im pretty sure this is a bad idea....bud esplain to me why you engineers out there! ) i like to learn
Mueller |
Mar 16 2004, 08:53 PM
the case "might" not be a real bad thing to coat, but the cylinders are a big no-no for this type of coating...
ceramic based coatings will trap and hold the heat inside of the cylinders, causing them to get even hotter which would of course transmit to the pistons and the heads. it would be similar to putting a blanket over the cylinder the reason i like the Jet-Hot is that they don't just simply spray the coating on, thier method uses a slurry (cream-of-wheat with too much milk) to coat the outside and the inside of the part |
Aaron Cox |
Mar 16 2004, 08:55 PM
do just the outside of the case then..... (IMG:style_emoticons/default/wink.gif) let us know how it goes!
TimT |
Mar 16 2004, 08:59 PM
jet hot is a heat "captive" sort of thing..keeps the exhaust gas hot... and within the pipes...therefore flowing more quickly
The coating works in two directions... say if you have a cold air source for the fan inlet.... if the fan housing is coated.. the cooling air would be from a nice cool source and no influence would be felt from the hot engine bay.. these coatings do work... to what degree needs to be proven |
Mueller |
Mar 16 2004, 09:32 PM
very good point Tim....I wonder if the coating would help the flow as well since it might be "smoother" than the cast aluminum????
mightyohm |
Mar 16 2004, 09:41 PM
magnesium alloy
Mueller |
Mar 16 2004, 09:52 PM
QUOTE magnesium alloy really?? it seems pretty darn heavy to be magnesium.......it must be alloyed with mostly aluminum (IMG:style_emoticons/default/smile.gif) |
Aaron Cox |
Mar 16 2004, 09:53 PM
type 1- 3 cases be magnesium. IV's are aluminum (rumor has it that a couple were made in magnesium in europe tho)
mightyohm |
Mar 16 2004, 10:08 PM
the fan housing is definitely magnesium alloy, it oxidizes so fast!
JeffBowlsby |
Mar 16 2004, 11:42 PM
914 Wiring Harnesses Group: Members Posts: 8,517 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Y don'cha crome the hole shebang mikeybro'....Im sereus...chrome 'er from da tin to da filterbox. that would match them cool weels and make a bold statement.
Dont misunderstand the tone of my post...I support you...wouldnt it be cool to see? (IMG:style_emoticons/default/cool.gif) (IMG:style_emoticons/default/cool.gif) (IMG:style_emoticons/default/cool.gif) |
jonwatts |
Mar 16 2004, 11:44 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
(IMG:style_emoticons/default/agree.gif) I like this idea. It's very "Mueller"
914werke |
Mar 17 2004, 01:20 AM
"I got blisters on me fingers" Group: Members Posts: 10,097 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Trust ME! Its MAG and hoo boy does it burn (IMG:style_emoticons/default/blowtorch.gif)
Andyrew |
Mar 17 2004, 01:40 AM
So whats made of mag?
I tested some stuff cus I like how mag burns, but nothing (this was a while ago... (IMG:style_emoticons/default/blowtorch.gif) ) |
Lo-Fi Version | Time is now: 24th May 2024 - 10:58 PM |
