What size plate do you think this is?, Anyone got pictures of this? |
Cire |
Nov 3 2009, 08:36 PM
Member Group: Members Posts: 279 Joined: 12-March 09 From: Tucson, Arizona Member No.: 10,155 Region Association: None |
Howdy all.
I was wondering about the plate and the bars in this rear cage. What size is the plate under the framing? Also, what size do you think that tube is? Do you think they put plate down under the trunk side too? Anyone got any pictures of this? Anyone ever done this? Suggestions? I want to stiffen up the rear end. Thanks. Eric |
ArtechnikA |
Nov 3 2009, 09:21 PM
Nov 3 2009, 09:38 PM
Resident German Group: Admin Posts: 41,633 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Howdy all. Thanks. What is the purpose of your build? If you're building the car to run with a certain organization, like SCCA etc. you need to get a rulebook. It will have all the answers to material choice and thickness ... (IMG:style_emoticons/default/shades.gif) Andy |
URY914 |
Nov 3 2009, 10:03 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,532 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
My quess is a 1/8" plate and 1" tubing to answer your questions without giving you a hard time.
Cire |
Nov 3 2009, 11:18 PM
IronHillRestorations |
Nov 4 2009, 08:04 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Andy is right though, if you plan to run in a certain class then you need to make sure you follow the rules.
If this isn't a dedicated competition car, you could be wasting time and trunk space. |
FourBlades |
Nov 4 2009, 08:41 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Isn't the logic of those tubes to stiffen the cross bar that your transmission is mounted to? I'm not sure how much side to side and twisting forces your transmission and driveshafts put on the rear of the car but it has to be something. Do you get better shifting action by using those bars? John |
Lo-Fi Version | Time is now: 12th May 2024 - 03:06 PM |
