Best CW Way to Add Gauges?, I'd like to add VDO Head Cyl. Temp. & Oil Pressure Gauges |
Tom_T |
Nov 4 2009, 05:19 PM
What, where & how would be the best way to add some supplemental Gauges to my early-73 2L's restoration?? (IMG:style_emoticons/default/confused24.gif)
I'd like to add the small 2-1/16" VDO Head Cylinder Temperature & Oil Pressure Gauges for the 914s, & have looked at VDO's 2-hole gauge bracket. However, I don't know if that will look decent, if I really want to drill to do an under dash mount of it to the L or R of the Wheel? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/dry.gif) I also don't want to cut-up the center console with some hincky 5 gauge face! (IMG:style_emoticons/default/barf.gif) I also want something that will pass CW muster! (IMG:style_emoticons/default/smilie_pokal.gif) Given the age of my 914 now & the fact that I'm resurrecting it from a 24+ year slumber (IMG:style_emoticons/default/yellowsleep[1].gif) - I think she's deserving of more monitoring than the factory provided, since I'll be driving it around some too. (IMG:style_emoticons/default/driving.gif) Any suggestions, examples, pix, etc. which could help me???? (IMG:style_emoticons/default/confused24.gif) |
detoxcowboy |
Nov 5 2009, 04:34 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Well read it again, also did you notice that with the vdo pressure sensor sender the psi threshold is lower than the factory dummy light threshold 7psi vs 11 psi so at idle sometimes your dummy light will flicker, any ways I understand what you want but also youe engine comp. with the pressure will be obvious and to get it not obvious you would have to cut your engine tin, most people use and extension tied down to the fan housing. but anyways ...
Tom_T |
Nov 5 2009, 05:52 PM
Well read it again, also did you notice that with the vdo pressure sensor sender the psi threshold is lower than the factory dummy light threshold 7psi vs 11 psi so at idle sometimes your dummy light will flicker, any ways I understand what you want but also youe engine comp. with the pressure will be obvious and to get it not obvious you would have to cut your engine tin, most people use and extension tied down to the fan housing. but anyways ... That flickering is not a problem, as long as you have the gauge, since you want to see the OP drop when the engine is running at higher RPMs - not idling. IIRC - mine used to flicker a bit even with the factory sender & idiot light when it was idling rough or loping, & when you came off the freeway after a long run at high speed, & the pressure drops suddenly to idle speed at the stop/light at the end of the off ramp. I'm not sure about what you mean by cutting tin, but that won't happen! I'll leave it visible or tucked away with a remote wiring/tube link before I start carving up my precious 914! (IMG:style_emoticons/default/dry.gif) ....screw the judges in that case! (IMG:style_emoticons/default/sheeplove.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 05:22 AM |
