Best CW Way to Add Gauges?, I'd like to add VDO Head Cyl. Temp. & Oil Pressure Gauges |
Tom_T |
Nov 4 2009, 05:19 PM
What, where & how would be the best way to add some supplemental Gauges to my early-73 2L's restoration?? (IMG:style_emoticons/default/confused24.gif)
I'd like to add the small 2-1/16" VDO Head Cylinder Temperature & Oil Pressure Gauges for the 914s, & have looked at VDO's 2-hole gauge bracket. However, I don't know if that will look decent, if I really want to drill to do an under dash mount of it to the L or R of the Wheel? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/dry.gif) I also don't want to cut-up the center console with some hincky 5 gauge face! (IMG:style_emoticons/default/barf.gif) I also want something that will pass CW muster! (IMG:style_emoticons/default/smilie_pokal.gif) Given the age of my 914 now & the fact that I'm resurrecting it from a 24+ year slumber (IMG:style_emoticons/default/yellowsleep[1].gif) - I think she's deserving of more monitoring than the factory provided, since I'll be driving it around some too. (IMG:style_emoticons/default/driving.gif) Any suggestions, examples, pix, etc. which could help me???? (IMG:style_emoticons/default/confused24.gif) |
tod914 |
Nov 5 2009, 04:43 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Tom how about swapping them out for the clock and volt gauge? Or do a staggered 5 gauge set up in the console. If you use velcro on the back of the gauge holder, you'll be able to easily swap it out with an original set up for events.
Tom_T |
Nov 5 2009, 06:11 PM
Tom how about swapping them out for the clock and volt gauge? Or do a staggered 5 gauge set up in the console. If you use velcro on the back of the gauge holder, you'll be able to easily swap it out with an original set up for events. Hmmmm..... (IMG:style_emoticons/default/idea.gif) Well Tod & Detox, I didn't want to have a screwy 5 gauge cluster - esp. since the center console is hard to see while driving anyway. ....but that 2 panel swap-out idea could work, but then I can just hear my wife will say: ...and you got two sets of gauges because......???? (IMG:style_emoticons/default/confused24.gif) ....as she prepares to cook my goose! (IMG:style_emoticons/default/stirthepot.gif) Another removable attachment idea I was considering, was to use one of the side-screws on the upper console bracket which connect the console to the under-dash, & have an extra longer screw/bolt with which to attach a 2 hole bracket on either the L or R side - with the gauges vertical - but don't know about leg clearance with it on that side. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/idea.gif) That could use the same hide the wiring trick as the excellent magnetic mount idea by Scott above. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 02:57 AM |
